Question about Mantis Crevice Cleaner Attachment
Tiller safety tips
What safety measurers should I consider while usuing a tiller?
    President:
  • 2,712 Answers
* As with any garden equipment, especially gas-powered, you should make sure you have adequate protective gear. * Safety goggles, work gloves and earplugs are all necessities. * Wear sturdy, steel-toed boots if you have them; if not, wear your most durable close-toed footwear. * If you plan to be out in the sun for a long time, don't forget a hat, sunglasses and sunscreen too!
Posted on Aug 27, 2008
  • 20 Answers
I also recommend wearing long pants, preferably jeans. If something were to get kicked up you wouldn't get injured or at least not as badly. as a general rule. always wear glasses/goggles, hearing protection, gloves, and pants. and soles with deep biting soles, like workboots or hiking boots.
Posted on Jun 04, 2009
What is the number on belt for a long life gold star tiller forward and reverse
from the looks of your antique tiller there is no way we could find out . measure the old one and go from there
Jul 19, 2016 | Garden
Have a honda fr800 tiller and will start but when i take the choke off it quits.
PDF]Untitled - Honda
cdn.powerequipment.honda.com/pe/pdf/manuals/31770620.pdf
This owner's manual is considered a permanent part of the tiller and ... FR800. HondaMotor Co., Ltd. reserves the right, however, to discontinue or change ...
Jul 25, 2015 | Honda Garden
Why tiller tines don't rotate
what style ??? large tine or little Mantis style ???
large, consider finding the belt and making sure it's engaging properly
small. consider a clutch issue. this requires dis-assembly of unit
Sep 01, 2014 | Garden
Oil smoke on my mantis tiller
Too much oil in the fuel mix. Look for a 2 cycle oil called Opti-2. Comes in 1 or 2 1/2 gallon mix pouches w/fuel stabilizer. One mix for all 2 cycle. It's the best and no measuring, foolproof.
Jun 07, 2009 | Mantis Tiller
Mtd 17.5 will not start
Riding mower have three safety switches. One under the seat, one under the clutch and one on the blade lever. Make sure all are making contact as the button tip can get worn after many uses. These can be replaced. One trick you can try before that..
Sit on the mower and pull the blade engagement lever back further than necessary and hold it in that position while trying to start it. This may work as it puts more pressure on the safety switch button and makes contact possible.
May 21, 2009 | Mtd Products Yard Machines 158CC Tiller
Soldering gun troubleshoot
# Never touch the tip of the soldering gun. They are very hot and will give you a nasty burn. # Take great care to avoid touching the mains flex with the tip of the gun. The gun should have a heatproof flex for extra protection. An ordinary plastic flex will melt immediately if touched by a hot gun and there is a serious risk of burns and electric shock. # Always return the soldering gun to its stand when not in use. Never put it down on your workbench, even for a moment! # Work in a well-ventilated area. The smoke formed as you melt solder is mostly from the flux and quite irritating. Avoid breathing it by keeping you head to the side of, not above, your work.
Aug 27, 2008 | Weller 8200 Soldering Gun
Soldering Question
# Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will give you a nasty burn. # Take great care to avoid touching the mains flex with the tip of the iron. The iron should have a heatproof flex for extra protection. An ordinary plastic flex will melt immediately if touched by a hot iron and there is a serious risk of burns and electric shock. # Always return the soldering iron to its stand when not in use. Never put it down on your workbench, even for a moment! # Work in a well-ventilated area. The smoke formed as you melt solder is mostly from the flux and quite irritating. Avoid breathing it by keeping you head to the side of, not above, your work.
Aug 27, 2008 | CRL Soldering Iron Temperature Control
Air hammer tips
Always keep in mind that air hammers are extremely powerful tools. Thus, particular safety precautions should be taken when using them. Be certain to wear safety equipment such as safety glasses and earplugs. Also, when changing the air hammer's bits, always be sure to unplug the air hammer first. Finally when using an air hammer, always be aware of the position of the tool and work piece. The tremendous force that the air hammer exerts can cause the tool or work piece to jump powerfully. This movement could easily cause injury to the operator.
Aug 27, 2008 | Ingersoll Rand Air Hammer 2 9/32" Stroke,...
Jig Saws safety problems
look out for the following safety features: * Safety switch or lock off button * Some saws have a soft start feature that starts the saw at a slower speed. * Blade guard that shields you during use
Aug 27, 2008 | Dewalt DC6KTJA 18v. Xrp Super 6 - Kit...
Mantis Crevice Cleaner Attachment Logo
386 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
