Question about Agri-Fab Agri - Fab Ground Drive Drop Spreader 175 - Lb. Capacity, Model No. 45 - 0288
Spreaders Guidelines are there any guidelines for calibrating a spreader?
Guidelines for setting spreader
Posted on Oct 30, 2008
    President:
  • 2,712 Answers
It is always a good idea to calibrate your own spreader, even if the manufacturer provides guidelines for setting the spreader with different products. It's easy to calibrate and, if you make a note of your results, you only have to do it once for each product.
Posted on Aug 27, 2008
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
How do you check to see if calibration is exact
Usually the cheaper residential grade spreaders are not exact, nor do they need to be. The best way to tell how close it is, is to measure the area to be fertilized length and width. Multiply the two numbers (example: 30' x 40' = 1,200sq ft.) Adjust the spreader according to the reccomendations on the bag, and follow the directions exactly! Walk at a brisk pace around the perimeter once, and then back and forth spaceing your passes about 5' for rotory spreaders. Compare the amount of product you used, to the coverage chart on the bag. In my experience, most all lawn fertilizers are best spread at 50% to 60% open on your spreader setting adjuster. (example: If your spreader has settings of 1-15, I'd go with 8) Always follow the directions on the product container as best you can. Spreading a little too heavy, or a little too light is not going to hurt anything, so there is no reason to be concerned with exact calibration unless you are applying discriminative herbicides... Hope this helps!
Oct 08, 2011 | Scotts Company 589384 Scotts 5000 SQFT...
I have Scotts deluxe edge guard. How go check calibration
The Scotts Edgeguard Spreader is calibrated at the factory. This spreader cannot be calibrated, and shouldn't need to be. For further assistance, call Scotts at 877-465-5160
Hilary @ Scotts
Aug 14, 2011 | Scotts Company Scotts Lawns Edgeguard...
How do i calibrate the spreader
Your AccuGreen 3000 Drop Spreader was calibrated at the factory. However, a spreader's calibration may change or slip over time or during periods of heavy use.
You may check the calibration of your Scotts Accugreen 3000 by first adjusting your micrometer setting to 6. Turn the spreader over so that you are looking at the outside of the bottom of the hopper. Use your foot to hold down the trigger (if your trigger has a locking mechanism you can lock it in place prior to turning upside down). With the micrometer set at 6 and the trigger squeezed against the handle, the front edge of the projecting ridge on the shut-off bar should be aligned with the calibration line located on the 2nd or 3rd tooth from the center. Some of the older AccuGreen 3000 Drop Spreader spreader models do not have a raised ridge. On these spreaders, line the front edge of the shut off bar to the calibration line.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and raised ridge or front edge of the shut-off bar meet. If you have any difficulty checking or adjusting the calibration, contact us and we will be happy to help walk you through the adjustment.
Again, thank you for taking the time to contact us and for your interest in Scotts. Please feel free to call us at 1(800)5438873 anytime we may be of assistance.
Mar 03, 2011 | Scotts Company Scotts& Accugreeen 3000...
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
How do i calibrate the accu green 3000
According to Scott's:
To adjust calibration, do the following: Adjust the micrometer setting to 6. Flip spreader over. Use your foot to squeeze the trigger against the handle. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. To adust alighment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Sep 18, 2010 | Scotts Company Scotts& Accugreeen 3000...
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
How do I calibrate my acugreen 1000 drop spreader?
The spreader comes already calibrated. The opening of the gate is determined by the setting that you input from the handle. This will correspond to the recommended settings provided on the fertilizer bag.
Best regards, --W/D--
Aug 09, 2009 | RTO Accugreen 1000 Drop Spreader
Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Apr 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Agri-Fab Agri - Fab Ground Drive Drop Spreader 175 - Lb. Capacity, Model No. 45 - 0288 Logo
2,142 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
