Question about Ryobi 30 Cubic Centimeter Gas Brush Cutter
Power Source Problem
What power source should I use?
    President:
  • 2,712 Answers
# Electric leaf blowers are lighter, quieter and vibrate less than gas units. An electric motor drives the fan, so there's no need to mix fuel or refill. Smaller yards are especially good candidates for electric blowers. There are two types: * Corded leaf blowers provide constant power as long as you have access to an electrical outlet. The attached cord limits mobility so this may not be the best choice for a lawn with lots of trees. Look for a cord retention system to prevent the cord from being accidentally unplugged during use. * Rechargeable/battery-operated leaf blowers are good alternatives for smaller areas or jobs. They work well on solid surfaces like driveways and garages. They're limited by their run time and the fact that they move less air than larger models. # Gas-powered leaf blowers use a 2-cycle engine, requiring mixing oil and gasoline. Mobility and work output are increased with gas blowers. They're louder and heavier than electric blowers.
Posted on Aug 27, 2008
Will not start, no click from starter, like its getting no power, but I have checked and pwr at ignition and pwr at starter but nothing but if I turn ignition on and jump solenoid it will start up !!
If under your own power source, vehicle is not starting...
then you connect an alternate power source, and it starts (as you said - right up) then your power source is bad!
Power Source = Battery
Jun 09, 2015 | 2000 Hyundai Accent
My prenter is showing ink system failure
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Mar 03, 2011 | HP Office Equipment & Supplies
Kyocera mita 5035 code 6400 c
Zero-crossing signal problem
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Dec 18, 2010 | Kyocera Mita KM-5035 Printer
No power even thougth power source is OK? No
If you know the power source is good then it's either a fuse, the cable itself or the power supply for the monitor.
Oct 25, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
It is a dell cpx lapetop. Will not start up.
change the power jack of the laptop..because the sounds like the ac power is not working in laptop..
Jan 04, 2009 | Dell Latitude CPX Notebook
Power source not charcing battery
Its not the battery, its AC power source providing your problem.
Check if AC connector goes in as far as it should on your laptop, check so you dont have a weak link on the cables on the AC. My guess is that the power sorce or the cables on is defect someway.
Nov 19, 2008 | Toshiba Satellite A100-S8111TD Notebook
Connecting new fan/motor assy
a capacitor is typically inline with your power source and stores a large amount of power to supply bursts of power when heavy draws occur. it sits between the source and the motor so you should have the (source - capcitor - motor) hot wires all conecting at the same place. The other wire on the capacitor should be the ground (if they have +/- markings use the negative as the ground).
Nov 14, 2008 | Amana 30 in. ACC3660AS Gas Cooktop
Ryobi 30 Cubic Centimeter Gas Brush Cutter Logo
198 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
