Question about Agri-Fab Agri - Fab Towable Broadcast Spreader 250 - Lb. Capacity, Model No. 45 - 0364
Spreader how to Maintenance
How to keep my spreader in good shape?
  • Anonymous May 05, 2009
    My spring is gone on my speedy greeen also....
    What can be done
    President:
  • 2,712 Answers
The professionals usually say that, after using a spreader, a thorough dry cleaning beats a sloppy wet cleaning any day. It's certainly a good idea to empty your spreader completely and shake out or remove with a brush any remaining material. Keeping moving parts lubricated helps too.
Posted on Aug 27, 2008
What setting is used to apply 1/4 lb per 100 sq ft?
BigVin, normally the bag of seed tell what setting to put spreader on for its proper application, If not try it on #4 setting, it all depend on how fast you wind and walk with a hand spreader. Good Luck.
Apr 04, 2016 | Scotts 71030 Easy Hand-held...
Cyclone spreader parts
Cyclone spreader parts can be purchased from amazon, take a look here: Amazon com Cyclone spreader parts. Wish you best of luck
May 16, 2012 | Garden
What setting should I use to set my pro spreder for pennington grasss seed?
I suggest a rotory spreader! How much turf are you planting? The rule of thumb is, you should see a light dusting of seed over the planting area before raking it in. You cannot put too much seed down, so remember that when spreading... The most important thing is, keep it wet for at least 30 days! Good luck!
Sep 18, 2011 | Scotts Company Scotts& Accugreeen 3000...
The impeller drive wheel of my classic drop spreader won't turn unless you have a huge load on board. I wash it out every time I use it and dry it thoroughly. I've removed the wheels and tried WD...
I am sorry to hear about the problem with your spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 877-465-5160 at your earliest convenience to check part availability. Hilary @Scotts
Aug 24, 2011 | Scotts Company Scotts Turf Builder Classic...
I have a i=2 year old Scotts lawn spreader. It is in good shape but the wheels fell apart. Where can I get replacement wheels
I am sorry to hear about the problem with your spreader. We should have replacement parts available to send. Please give Scotts a call @ 1-800-543-8873 at your earliest convenience to see what we can do to assist you.
Feb 11, 2011 | Scotts Company Scotts& Accugreeen 2000...
Spreaders Guidelines
It is always a good idea to calibrate your own spreader, even if the manufacturer provides guidelines for setting the spreader with different products. It's easy to calibrate and, if you make a note of your results, you only have to do it once for each product.
Aug 27, 2008 | Agri-Fab Agri - Fab Ground Drive Drop...
Drop and Broadcast Spreaders comparison
There are two common types of lawn spreader: drop or broadcast. The drop spreader is a familiar sight at garden centers and hardware stores. If you are a homeowner with less than 5,000 sq.ft. of lawn area, an inexpensive drop spreader may be all you need. Drop spreaders tend to be more manueverable in tight, awkward spaces and are relatively easy to use. Broadcast spreaders throw the material out in a wider swath, sometimes as wide as 8'. If you have a large area to cover, they can make short work of it. They are, however, a little trickier to use, since you need to keep up a steady walking speed (usually 3 mph) and you need to be moving when you activate the spreader. It's also harder to get a clean edge, although some broadcast spreaders come with side deflectors, which let you get close to side-walks, beds and driveways without spreading material on these adjacent areas. There are also small, hand-held broadcast spreaders suitable for smaller areas.
Aug 27, 2008 | Agri-Fab Agri Fab Spreader
How to use Spreaders
Follow the specific spreading instructions that come with your spreader. When working with spreaders, always load a spreader on a surface where an accidental spill can be cleaned up and won't matter (driveway, walkway, etc). Common practice is to first run the spreader around the periphery of the area you are treating; this ensures a consistent application around the edge of your lawn. Next, you run the spreader back and forth within the area bounded by your first perimeter run. Always allow on overlap to avoid missed streaks or "holidays". Ideally, apply your material at half the recommended rate and make two sets of runs, first back and forth in one direction, then again another set of runs at 90 degrees to the first set. This ensures a good consistent coverage and it compensates for any uneven patches.
Aug 27, 2008 | Scotts Company Scotts& Accugreeen 3000...
Agri-Fab Agri - Fab Towable Broadcast Spreader 250 - Lb. Capacity, Model No. 45 - 0364 Logo
1,061 people viewed this question
Top Agri-Fab Garden Experts
Joseph Mueller
Joseph Mueller
David Ellis Rhea
Ray Smythe
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
