Question about Toro Lawn Mower With Toro Power Tools
Vacuum or Blower?
When should I use vacuum or blower?what is the difference?
    President:
  • 2,712 Answers
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Posted on Aug 27, 2008
3 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: craftsman leaf blower/vacuum
I have a Craftsman and you should have a separate attachment to it. Your motor will turn the same, instead of pushing air out the pipe, you will draw air in through the air intake.
Posted on Feb 03, 2009
SOURCE: turning the vacuum on.. paramount pb350
That blower vacuum is very easy to operate if you have all the pieces. You need the tubes to blow, you need the larger tub to vacuum and if you want also a bag to attach to the bigger tube. The bigger tube has to be attached at the opposite part of the machine and once you turn it on it will vacuum.
Posted on Jun 11, 2009
How do you get it to vacuum?
If you got all the parts you will find an adapter that fits over the air intake system for the blower. That is the vacuum source.
Jul 05, 2013 | Poulan Pro BVM200VS 25CC Gas Leaf Blower...
After fixing blower motor it only blows out defrost
some a/c / heater actuators are controled by vacuum vacuum line may be pinched or broken when you did your repair,diesels have vacuum pump that suply vacuum for differant things,because diesel engine can not produce vacuum it self.if vehicle happens to have electric acuators then something may have been left unpluged or you may have blown a fuse
Aug 01, 2012 | Dodge Cars & Trucks
Heater vents close and it sounds like blower motor gets louder when passing gear is used
You most likely have a vacuum line leak -- could be in a hose run to the vacuum motors which operate the duct doors or various other places. Vacuum drops off when engine is rapidly accelerated which reduces the vacuum the heating system motors receive. The blower motor seems to get louder because the closing of the doors provides the sound of the motor a different (more open) path to your ears.
Charlie
Feb 08, 2011 | 1994 Chrysler Town & Country
Where do i switch theLEAF HOG FROM VACUUM TO BLOWER
Remove vaccuum tube. Allow the access door for the vacuum tube to shut all the way. Attatch the blower tube where you had the collection back for the vaccuum attatched. That is it.
Feb 01, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Older leafhog don't know how to change over to blower instead of vacuum model Bv2500
Remove the vacuum tube completely from the bottom of the machine and make sure the impeller cover closes completely. Remove the collection bag off of the blower outlet. Now attatch the blower tube to that outlet on the blower. Done.
Dec 07, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
How to do I convert it from blower to vacuum..it just stopped sucking and the blowing is not strong
My LEAF HOG works fine on blowing - but when I switch to vacuum it wor't
start. What's the difference from going to Vacuum from Blower???
Dec 03, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
How do we activate blowing system on the blower/vacuum? I don't know how to switch from vacuum to blower?
1) the pick-up tube for vacuum is removed
2) the vac bag is removed and blower nozzle is installed in it's place
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
Blower not working
If the blower motor resistor is bad, the fan will run only on the high speed setting. In your case, you state you have no air coming from the dash vents, indicating that the blower is working. The control of air flow is done with vacuum-operated baffles that steer the air to the different possibilities. If it isn't changing with your different settings, you may have a broken or loose vacuum line or the very frail fitting on the vacuum reserve tank is snapped off - have seen this on GM stuff before.
The tank normally a cylindrical device 6-8" across and high. it should have two small fittings on which there should be vacuum lines. It is often located close to the firewall.
May 20, 2009 | 1994 Chevrolet Lumina APV
Blower motor in 1993 dodge dakota
u must have knocked the vacuum hose off when u changed the motor, that (vacuum) is what moves the air to the different outlets, the vacuum comes from the engine and enters the cab on the passenger side..
May 12, 2009 | 1995 Dodge Dakota
The leaf hog BV4000
Put the switch in the center off position. That allows you to press the big black button in the front and take the vacuum attachment off. Replace the vacuum with the blower attachment and you should them be able to blow rather than vacuum.
Oct 25, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Toro Lawn Mower With Toro Power Tools Logo
690 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
