Question about Ryobi 26CC, 22 In. Hedge Trimmer
Trimmer weight problem
What weight of trimmer should I use?
    President:
  • 2,712 Answers
Blade size will determine the hedge trimmer's weight. Make sure it feels comfortable as you will be holding it for long periods of time at awkward angles.
Posted on Aug 27, 2008
How do I put the blade back
Husqvarna Hedge Trimmers 122HD60
www.husqvarna.com/.../hedge-trimmers/122hd60/966...
Husqvarna GroupHusqvarna 122HD60 is a low noised and light weight hedge trimmer for domestic ... 23 inch. Weight. 10.8 lbs. Add to wish list Find a dealer near you. Manuals.
Oct 13, 2015 | Husqvarna 122HD60 Hedge Trimmer
What makes line come out automatically?
A weighted swing arm inside the trimmer line head that is rpm sensitive.
Jun 04, 2015 | Homelite 14 in. 5 Amp Electric String...
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Why is my line coming out too fast
The retractor counter weight needs to be replaced or more weight added to devise
Jun 21, 2014 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
What oil weight is used in the TB 575
If it is a 2 cycle motor, then use an appropriate 2 cycle oil. I use a synthetic oil that 1 bottle is mixed with 1 gallon of fresh gas.
May 09, 2014 | Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas...
I have a weed eater max te475 trimmer and would like to know what size of trimmer line should i be using.thnx...........Michael
For a lighter weight machine with the smaller 25 or 26cc engine like yours, .085" line is sufficient. .065" line is for electric trimmers and .095" line is for trimmers with the larger 30 and 32cc engines.
Aug 14, 2011 | Poulan Garden
Weedeater starts ok but as soon as you tilt it downwards it shuts off.
The fuel line in a trimmer usually has a weighted fuel filter so that no matter which way you tilt it, the weight pulls the filter down toward the pool of fuel in the tank. If this weighted fuel filter gets caught or stuck in one corner of the tank, then it won't fall properly in the tank to the fuel level so it then runs out of fuel. Look into the fuel tank, with no fuel in the tank, and make sure it moves freely when you roll the trimmer around.
Jul 04, 2010 | Craftsman 25cc Gas Line Trimmer
What size line do I need for a Ryobi ELT1000FA Trimmer
A good Rule-of-Thumb for homeowner trimmers is:
Curved shaft trimmers need to run .065-.080 diameter line while straight shaft trimmers can handle .095-.115 diameter.
Keep in mind the kind of use the machine gets and match line diameter accordingly. Larger line may fit into the spool, but the power and RPM that's available to you will suffer because of the extra weight and wind resistance.
Hope this helps!
Oct 01, 2009 | Garden
Troy Built 4-cycle engine Trimmer
there should be a label stating the oil type somewhere on the engine or cap or owners manual, if not most manufacturers recomend a 30 weight oil. be sure to drain out the old stuff first.
Sep 21, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Ryobi 26CC, 22 In. Hedge Trimmer Logo
123 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
