Question about Bond Manufacturing 6-pieceUltimate Pruning and GardeningSet
Blade length problem
How can rhe blade length and width effect my work?
    President:
  • 2,712 Answers
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Posted on Aug 27, 2008
What size/type blade is needed for this brand of saw?
check inside the cover of the saw and there should be a decal with the saw length and width for the machine
the number of teeth on the band will depend on the material being cut
failing that run a tape measure around the wheels and the length will be that with probably less 5 mm to allow to tension adjust,ment
Aug 21, 2015 | Blade Saws
What size of blade
The blade length is probably almost 100" , but I suggest you try to calculate the length , try this method Calculate Belt or Band Saw Blade Length VintageMachinery org
Jul 08, 2014 | Saws
BANDSAW BLADES
AWSBS2 band saw takes 70 1/2" long blades. Blade Widths : 1/4", 3/8", 1/2" .
Apr 14, 2014 | Saws
P=228 width is 24 ft less than the length
Say length is x.
Width is x-24.
Perimeter is length plus width plus length plus width = 228.
x + (x-24) + x + (x-24) = 228
4x-48 = 228
4x=276
x=69
length = 69
width = 69-24= 45
check: 45 + 69 + 45 + 69 = 228
Dec 18, 2013 | Computers & Internet
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Bond Manufacturing 6-pieceUltimate Pruning and GardeningSet Logo
191 people viewed this question
Top Bond Manufacturing Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Bond Manufacturing Garden Expert? Answer questions, earn points and help others
