Question about Husqvarna 26hp 54" Ztr Tractor
What is ZTR? - Husqvarna 26hp 54" Ztr Tractor
    President:
  • 2,712 Answers
A ZTR mean Zero Turn Radius. Riding mowers are zero turn radius. Tracktors are not.
Posted on Aug 27, 2008
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
ENCORE Z ZTR with park brake issue
I googled: ENCORE Z ZTR with park brake
Try this or one of the others
http://www.encoreequipment.com/test/wp-content/uploads/2012/06/42B350Z-OPERATORS-MANUAL-933077.pdf
Apr 05, 2015 | Garden
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
Why is my Cub ZTR 50 keep braking belts? I only got 30 minute out of the last one at $40.00 a pop I can't keep going on.
check all the blade spindles for seized bearings. also check the pulley alignment, those issues can cause premature belt failure. Also proper tension can give you consistent long term use.
Dec 03, 2012 | Garden
What causes ztr front wheel to squeek in motion?
i would take them off and clean off the old grease and apply fresh grease on all moving parts including the the wheel caster section
Jul 14, 2012 | Toro Zero Turn Rider 74366 Lawn Mower...
I have a 05 Toro 44in ZTR with a 19HP Kawasaki engine with under 300 hours the main 30amp fuse keeps blowing when I turn on the ignition switch on. I noticed when I disconect the PTO switch the fuse dousnt...
sounds like your electric clutch is prob bad check to make sure wires are not bare touching something, the clutches do go bad eventually like any other electrical part, disc the pigtail and try fuse, if it blows then I would consider a clutch
Jul 27, 2011 | Toro Zero Turn Rider 74833 Lawn Mower...
Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Jun 05, 2009 | Garden
Headlight Kit for my Craftsman ZTR Lawnmower
Without your model number, I can not access information to see if they made a light kit for this mower. I have seen very few ZTR with light kits.
However I have seen a couple of mowers with lights on them. They got creative; they put some fog lights from an automotive store. They hooked up to the battery on the mower with a switch in line. It may be the way you have to be creative yourself. Hope it helps; Keep cutting
Good Day.
Apr 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Husqvarna 26hp 54" Ztr Tractor Logo
272 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
