Question about Chapin Industrial 3 Gallon Viton Cleaner/Degreaser Sprayer #22360
Sprayer Support what can I do with a sprayer?
    President:
  • 2,712 Answers
Measure the exact amount of material required for the job. Adjust the spray precisely - from coarse, drenching coverage to very fine mist to a long range pinpointed stream. Start and stop the spray quickly and at will. Prevent over-spraying by using the long-reaching hose and spray wand. Spray up or down as well as underneath leaves (where most insects and plant diseases can be found). Buy concentrated lawn and garden treatment materials, which in many cases is more cost-effective than the pre-mixed versions.
Posted on Aug 27, 2008
2 Suggested Answers
SOURCE: sprayer wont spray or hold pressure
We use the both the 425 and 475 solo sprayers most days at work and when they start to lose pressure ( after 6 months of daily professional use) we purchase a complete seal kit and put it through them. The only part I can't work out how to remove is the inside cylinder, other than that everything else is easily removed and replaced.
Posted on Mar 27, 2009
My sink sprayer stopped woking (no water goes to it and nothing is leaking
Debris has come through the water supply and clogged the sprayer, remove debris and test sprayer
Sep 01, 2014 | Niagara Commercial Kitchen Pre-Rinse Sink...
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
Feb 22, 2014 | WD-40 Foaming Bike Wash 1L With Sprayer
The top sprayer holes on sprayer arm are blocked, how does sprayer arm come apart to clear blockage?
The sprayer arm does not come apart. You have to remove the sprayer arm and use an object that fits in the holes to clear the blockage.
May 28, 2012 | Kenmore Dishwashers
I use a powder fertilizer in my sprayer. What is the "ratio" of this sprayer? I use setting 4.
Directions on the sprayer are not the factor here, the directions for use on the product are. In any event we don't have this info, if you are unsure call the manufacturer or contact a garden supply shop. DO NOT USE TO HIGH A CONCENTRATION, IT WILL BURN THE PLANTS.
May 18, 2012 | Ortho Dial N Spray Hose End Sprayer
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Herbicide sprayer stopped working
sometimes the tube/straw on the inside of the sprayer where the water comes thru falls off its connection.If you put the end of the hose in the sprayer you may have knocked it off.Depending on sprayer it can be easy or a pain to put back on
Apr 11, 2010 | Chapin Spectracide Sprayer
Moultrie 25 gal spot sprayer for water sealer treatment
Yes, I've used pumpup hand sprayers to apply sealers. Is the sealer water-based? If not, cleaning up the sprayer afterwards could be a chore!
Mar 01, 2010 | Moultrie 25 Gal. Spot Sprayer
Moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Jul 20, 2009 | Plumbing
Sprayer Gun Problem
Before choosing a garden sprayer you must identify the problem. Some areas can be spot-treated with small amounts of pesticide, other areas (such as lawns or large gardens) need a larger capacity sprayer. Sprayer sizes vary greatly, from 1 quart to 4 gallons, so finding a model to fit various gardening needs will not be hard.
Aug 27, 2008 | Chapin Industrial 2 Gallon Viton...
Chapin Industrial 3 Gallon Viton Cleaner/Degreaser Sprayer #22360 Logo
326 people viewed this question
Top Chapin Garden Experts
Nick Olsen
Are you a Chapin Garden Expert? Answer questions, earn points and help others
