Question about Sp Systems 02sv320065 Farm & Home 2 - Gallon Compression Sprayer
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Posted on Aug 27, 2008
The unit harness broke and I was wondering if the Stanley has a replacement ?
Posted on Apr 24, 2013
May 28, 2017 | ATVs
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Dec 04, 2010 | GE Dishwashers
Dec 04, 2010 | Bosch Dishwashers
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dec 02, 2010 | Asko D1776 Stainless Steel Built-in...
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dec 02, 2010 | Dishwashers
813 people viewed this question
