Question about Ultra Max R. L. Flomaster Atomist Electric Sprayer' Ultra Low Vol , 2 Gal. Janitorial Supplies
Sprayer tips what safety measures should be taken when using a sprayer?
    Habit-Forming:
    New Friend:
  • 107 Answers
Looking for Paint Sprayers and Paint Supplies to paint surfaces?
With 10 years of experience building and perfecting the highest quality
equipment and supplies, http://www.pro-paint-sprayers.com/ has the solution
you're looking for.
Posted on Jul 14, 2016
    President:
  • 2,712 Answers
Read and FOLLOW EXACTLY the spray material directions for mixing and use. Wear protective clothing including gloves and eye protection when spraying. Do not smoke, eat or drink when spraying; "wash up" afterwards. Spray on a calm day. Otherwise, winds may blow spray material off target. It's often best to spray in the early morning or late afternoon so excessive heat won't quickly evaporate the spray material. Follow the directions for use and maintenance that come with your applicator. Dispose of left over spray material and clean your applicator according to the directions on the spray material and with the applicator. Keep spray materials and applicator away from children and pets. Do not store spray materials in any but the original container in which they were purchased.
Posted on Aug 27, 2008
What is the mixing ratio to 1 gal of water?
Their products are here, but they don't tell you the usage. It has to be on the label by law. The rear label usually lifts up to reveal a small book of three or four pages. If it isn't there, contact the company via the website.
http://www.spectracide.com/Products-and-Solutions/Lawn-Weed-Killers.aspx
The does have label details here
http://www.spectracide.com/Customer-Help/Labels-and-MSDS.aspx
For the Spectracide it is 1/2 oz to a gallon, but it depends on what type of grass you have. I will copy and paste the label details, but I doubt the format will stick, but it is all there.
Ounces of Concentrate to Use for:
St. Augustine*,
Bahia,
Centipede
2/3
2 2/3
13 1/3
21 1/3
32
32
1/2
16
250
1,000
5,000
8,000
Sq ft
to be
Treated
Bluegrass,
Fescue, Rye,
Zoysia
Gallons
of
Water
*DO NOT USE ON FLORATAM VARIETY OF ST. AUGUSTINEGRASS IN
FLORIDA.
HOW MUCH TO USE
SPOT TREATMENT
To spray small areas or individual weeds, use a pressure sprayer for better
control. Do not use a hose-end sprayer. Mix as directed in table below. Shake
well before spraying. Be certain to wet each weed.
ENTIRE LAWN
PRESSURE SPRAYERS
Measure amount of concentrate from chart below into sprayer tank and dilute
with 1 gal of water. Close tank sprayer and shake well before spraying. Use a
spray pattern that gives small spray droplets without any ne mist to treat
250 sq ft.
HOSE-END SPRAYERS
"CONCENTRATE ONLY" (DIAL) SPRAYERS
1. From the chart below, determine amount of concentrate to be applied for
each 250 sq ft of lawn.
Bermuda,
Bentgrass
St. Augustine*,
Bahia, Centipede
1/2 - oz
2 - oz
2/3 - oz
2 2/3 - oz
1 - oz
4 - oz
1/2 - oz
2/3 - oz
1 - oz
Grass
Type
Ounces in
Sprayer
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
250 sq ft
1,000 sq ft
Area
Treated
Dial
Setting
Bluegrass, Fescue,
Rye, Zoysia
FLORIDA.
2. Fill sprayer jar with enough concentrate to cover area to be treated. Do not
add water to sprayer.
3. Set dial on sprayer to the setting from the chart below.
4. Attach sprayer to hose. Extend hose to the farthest area of lawn to be treated
and work back toward faucet so that you do not walk over treated areas.
Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue lawn, add 4 - oz of concentrate to the
sprayer with sprayer dial set on 1 - oz. Check the directions you received when
you purchased your sprayer for further details on the proper use of your dial
sprayer.
"CONCENTRATE-PLUS-WATER" SPRAYERS
For sprayers that require the addition of water as well as concentrate prior to
application:
1. From the following chart, determine amount of concentrate required to treat
2. Pour concentrate into sprayer jar to the required "- oz" level.
3. Then add the appropriate amount of water to the "gallons" level. Replace
sprayer top on jar and shake well before spraying.
treated and work back toward faucet so that you do not walk over treated
areas. Apply evenly to lawn.
EXAMPLE: To treat 1,000 sq ft of fescue, pour in concentrate to the 4 - oz mark
and add water to the 4 gal mark. Check the directions you received when you
Lawn Weed Killers
Apr 18, 2016 | Spectracide Bug and Weed Killer for Lawns...
My maytag jetclean dishwasher quiet pack makes a grinding noise and the sprayer doesnt spin
Take apart the sump filter area and check to see if anything is stuck in the impellers for the wash motor.
Jan 01, 2015 | Maytag Dishwashers
Unable to remove lid from pressurized weed sprayer
you just have to hold down the trigger till all the pressure is drained off
Jul 30, 2014 | Roundup "" Weed & Grass Killer
Owners manual for a campbell hausfeld model # AL233300LX airless sprayer
http://www.chpower.com/manualsearch/
Manuals for Model: AL2333Manual Description Classic Mega Bytes
AL SeriesParts List- AL Airless Breakdown.6AL SeriesParts List- AL Airless Models - Breakdown with Block- 2001.073.1AL SeriesSafety Sheet- 2011.06AL SeriesSpecifications- Airless Tip Compatibility.3AL SeriesSpecifications- Paint Tip Selection Chart- 2003.04.5
Nov 12, 2011 | Campbell Hausfeld Airless Spray Guns &...
Can I find the nozzle tip for this sprayer at Home Depot or Lowes?
Yes. Home Depot sells Spectracide sprayers, hoses, and tips. Typically they are by the lawn mowers and rakes.
Jul 16, 2011 | Chapin 2 Gallon Spectracide Sprayer
Frigidaire dishwasher doesn't seem to wash top rack. The dishes are oily with stuff dried on them. It worked for several years before this. I took out the sprayer and ran water thru it to make sure it...
Have you taken the tube that goes to the top sprayer off and washed that out as it may be clogged especially where the sprayer goes on it has a small opening.
Oct 27, 2009 | Frigidaire Dishwashers
Sprayer Support
Measure the exact amount of material required for the job. Adjust the spray precisely - from coarse, drenching coverage to very fine mist to a long range pinpointed stream. Start and stop the spray quickly and at will. Prevent over-spraying by using the long-reaching hose and spray wand. Spray up or down as well as underneath leaves (where most insects and plant diseases can be found). Buy concentrated lawn and garden treatment materials, which in many cases is more cost-effective than the pre-mixed versions.
Aug 27, 2008 | Chapin Industrial 3 Gallon Viton...
Ultra Max R. L. Flomaster Atomist Electric Sprayer' Ultra Low Vol , 2 Gal. Janitorial Supplies Logo
597 people viewed this question
Top Ultra Max Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ultra Max Garden Expert? Answer questions, earn points and help others
