Question about Drive Medical Sun Shade for Scooter - 1 Each
Electric scooter battery problem
How long will my batteries last before they are worn out?
  • Anonymous Feb 15, 2009
    shoprider battery pack can't find
    President:
  • 2,712 Answers
Some low end electric scooter provide 200-400 full charge-discharge cycles for a battery. Many scooter batteries will operate over 500 times.
Posted on Aug 27, 2008
Sccoter's batteries are two years old, fully charged but when the scooter goes forward or backward, it makes a clicking noise and just stops for no reason.
Charge the scooter and test the volts cheap volt meter. When you hear the clicking retest. If the voltage is way down the battery is bad. If voltage is ok then and electrical component like a relay needs to be replaced. Any small electronic shop can repair it. Also, Google the model and clicking behavior to see if a turn key fix exists.
May 05, 2015 | RTO Mega Motion 3 Wheel Travel Pal Scooter
What type of batteries does this model take?.jb.
you need 12v 33ah sealed deep cycle battery most likely it may need two batteries any thing above 33 amp hours would also be ok. A higher Ah the longer the batteries last. This information on the type of battery is from the user manual.
http://www.hardwarexpress.co.uk/rascal-388-mobility-scooter-battery-1949-p.asp
Any battery type store should be able to supply this to you .
Feb 10, 2015 | Electric Mobility Rascal Scooter...
E300 electric scooter battery,
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
Mar 19, 2014 | Razor E300 Scooter
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Charging problem and also it never stands for a long time , new charger is again given from the company but no use , pls help
If you have recieved a new charger, are charging the batteries for 8-10 hours and the scooter has not been stored for a while, the batteries may need to be replaced. Do you have any flashing lights on the controller? Is there any noise or vibration when you operate the scooter that might cause fast battery drain? Batteries usually last 1-2 years with proper self maintenance; if your batteries are older than this they may just be worn out and need to be replaced.
Oct 11, 2010 | Health & Beauty
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
Jul 09, 2010 | Electric Mobility Mobility Electric Power...
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN...
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
I have a 4 wheeled shoprider sunrunner scooter. Only 3 lights on led light up batteries are fully charged?
Possible one or both batteries have had there day. How old are the batteries. If they are between 1 and 2 years old they will probably need replacing. it would be adviseable to get the batteries tested and have the charger checked as well. When did it have its last service ?
Jun 26, 2010 | Electric Mobility Shoprider Electric Power...
New 55ah batteries but charge won't last.
Battery life is affected by many things. But inside a tiled space like Walmart is probably the best possible running conditions. Make sure your tires are fully inflated, and you may need to have the motors check for worn brushes or maybe the wheel bearings are dry. Does the scooter push hard when in free-wheel mode? You may also need to have your charger checked, to be sure your batteries are really being fully charged.
Nov 22, 2008 | Pride Maxima 4-Wheel 4-Wheel Scooter
Drive Medical Sun Shade for Scooter - 1 Each Logo
519 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
