When you pick up the phone and hear nothing or a series of electronic beeps, assume that this may be a TTY call. Put the phone on the TTY coupler (usually the mouthpiece goes into the left acoustic coupler) and make sure it fits snugly into the acoustic cups. Turn on the off/on switch. (Do not assume it’s a prank call and hang up).
Call services
From your phone, you'll be able to access and change the settings of various call
services for your phone.Contact your mobile operator to find out about the availability of call services.
From the Home screen, press MENU and then tap Settings > Call.
Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this
feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings
Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification
If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode
Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings
Edit the call reject message, choose whether to open the message
editor when you reject a call with a message, and choose whether to
allow automatic saving of an unknown contact number when a call
with that number ends.
Cell broadcast
Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings
Configure channels and language for cell broadcast messages.
Call forwarding
Select how you want your phone to handle busy, unanswered, and
unreachable calls. You can also set the call forwarding option for all
incoming calls.
Call barring settings
Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
Updates are always available online.
If you try to add unathorized gadgets to your TTY, you could have problems. Always check the owners manual for "dos and don'ts."
I found the manual for this machine. It has setup instructions with illustrations and troublshooting instructions, it should help with testing your machine.-->
http://www.ultratec.com/manuals/MinicomIV_Manual.pdf
TTD/TTY devices use normal phone lines to communicate. An individual with a TTY/TDD can either communicate with another TTY/TDD device or can make a call to a standard telephone. In this case, the TTY/TDD device calls a live relay operator and the live relay operator communicates with both parties either with a TTY/TDD device or uses their normal human voice on a standard telephone. It is important to note that there are different protocols that can be used to communicate with TTY/TDD devices, however many newer TTY/TDD devices can handle a wide range of protocols and can even communicate directly from a personal computer using special software and a computer modem.
Try disabeling TTY unless you need it it (it is a hearing impaired function). To disable do the following: In idle mode press the Menu soft key to access menu mode, Select Settings and highlight Phone Settings, Press the Select soft key or the Cingular key, pres the 5 key and highlight the Disable selection, Key in the password: 4889, Press the OK soft key For additional technical support call 888-987-4357
