Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Can't see an image on TV
I Connected My Camcorder To My Television But Cannot See An Image.
    Master:
  • 473 Answers
The camcorder should be connected to the TV's A/V input jacks using the A/V cable supplied with the camcorder. Turn on the TV and access the TV's "Video" or "Auxiliary" mode.
Posted on Sep 06, 2005
How to project an image from an external device from a Sony Camcorder HDR-PJ240E?
Simple solution. You connected an output to an output. The Camcorder 'outputs' image from it so you need to plug it into an input on your TV. You will then see image from the camcorder on your tv.
Nov 25, 2014 | Sony HDR-PJ240E/B Full HD Handycam...
My wii when i turn it on it only has lines going across the screen.. about a week back it was saying something about the memory. now it wont load the wii menu nor will it load any games... if anyone knows...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Was this information helpful?
Nov 02, 2012 | Nintendo Wii Console
Wii in black and white
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
I use attached the pc on tv but i didi not here any sound please tell me sound pin cable attached the tv?
Hi sahazada pak,
As i know, TV set not support sound from PC input.
If you want here sound and still working with PC, you should use HDMI or DVI input from your PC out. HDMI has support image and sound in one cable. DVI only image without sound. if you use DVI , sound pc should connected to audio in.
Good luck.
Mar 22, 2011 | Samsung HLP6163W 61" Rear Projection...
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The image expands off the screen of my HD tv
Look in the menu for an image adjustment option. This is used to center or adjust the given image. Try a different type of connectiong from the cable box to your TV. ie; if you are connected by component connection, try AV or HDMI to test. If that doesn't work, look at the cable box settings (call your cable company for instructions) or have the box replaced if defective.
This is common for PC connections but not for cable.
Dec 21, 2008 | Televison & Video
Playing camcorder video on TV
Hello there. The only way to hook up your camcorder to the tv is if you change the settings of your camcorder. Every camcorder has a different setting menu so you might just have to look it up in the manual. Or maybe your cables are not connected properly.
Dec 16, 2008 | Video Cameras
Camcorder Widescreen Recording Issue
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Capturing a video from the console
It's not a problem, it's designed that way. Its called Macrmedia Encryption. It's so you can't record commercial DVD's onto other media (anti-piracy). Since the game is DVD based, it will not be recordable.
Sep 17, 2007 | Sony PlayStation 2 (PS2) Console
I can't get a picture on my television when I have my Viewcam connected into my VCR.
Make sure the Viewcam is connected (cable supplied) to an A/V input on your VCR. Set your VCR to the Line In or Auxiliary mode. Turn the Viewcam to Camera or VCR mode if playing back tape. Viewcam image should appear, if not call 1-BE-SHARP.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
91 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
