Question about Plantronics Dialogue Iiip Clarity Ameriphone Tty Machine With Printer
Hearing Aid Battery Problem
How long do hearing aid batteries last?
    President:
  • 2,712 Answers
This depends on how much energy and power the hearing aid needs, how often you use it and what type of hearing aid it is. Some batteries may last days while others can last weeks. Consult your hearing professional and read through information supplied by your battery manufacturer to ensure that you follow the steps to maximize the life of the batteries.
Posted on Aug 27, 2008
Problem with hearing aids
Try another set of batteries, Annmichelle. Sometimes "new" batteries are dead, too. I doubt very much that your tool has killed your hearing aids.
Aug 04, 2014 | Health & Beauty
Tip
How do i replace my battery in my hearing aid?
First you turn down your hearing device and open the latch on the inner side of the hearing aid,take out the old battery,then you simply pop in the new battery,shut the latch and put it right back into your ear.Then turn it on of course and your good to hear again.
on Jan 21, 2010 | Health & Beauty
My right hearing aid is 4 momths old and it stopped working
The Bolero model requires clear passage of sound through the tube that connects it to the dome/tip that fits into your ear. To determine if the tube is blocked, with a good battery inserted and the battery door closed, unscrew the top of the tube where it connects to the hearing aid. If you cup the hearing aid in your hand, it should whistle/feedback. If not, there is something wrong with the hearing aid. If it does whistle, your audiologist should have provided you with a thin, flexible plastic piece (often green) and instructed you how to unscrew the tube at the top of the hearing aid to run the plastic piece through the tube, all the way out the other end of the dome/tip. If that piece can travel the entire tube easily, then sound should be able to. In any case, a Phonak hearing aid has at least a one year manufacturer warranty (a Q90 likely has a three year) and they will pay for shipping both ways to fix it. You need to send it via an audiologist, though.
Jun 08, 2014 | Phonak Bolero Q90 BTE behind the ear...
Siemens charger for hearing aids starts charging and then after some hours one light goes red
Its a warning sign for a faulty battery, the red light comes on if the battery is faulty or if you are trying to recharge a non rechargeable battery.
May 03, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
My mother in law is very deaf in one ear and has poor hearing in the other. How can I tell if her own hearing is at fault or her hearing aid battery needs changing or there is some other fault causing her...
I have a similar issue with my 86 year old mother-in-law and her hearing aids. Depending on how long they are worn/turned ON, determines how long the battery in each one will last. In my mother-in-laws case, she waits to long to change the batteries or doesn't keep the volume turned up high enough. So, in her case, the battery(s) get weak, before she realizes it. The other thing that is most important is when we age our body (ears in this case) physically change and the hearing aid(s) that were originally fitted several years before, don't fit as well as they should. I am also convinced that their hearing continues to deteriorate and they should be tested and fitted with a new hearing appliance, as needed.
The down side to this, is that hearing aids are not inexpensive. So, if Medicare, Medicaid or their own private insurance want cover at least part of the cost, most people don't want to pay for new ones. Or as my mother-in-law says, "Oh, they're working alright." When in fact, they're not. My wife and I can tell by the volume on her TV. When you can hear it from one floor to another, her hearing aids aren't working right.
Apr 11, 2011 | Health & Beauty
Hearing aids keep shutting down. Batteries get wet.
First you should probably keep your hearing aid and battery away from water.I suggest taking it out while in the shower/bath and cover your head with a hood or umbrella while out on a rainy day.If battery keeps shutting down then replace the old battery with a new one.If problem keeps accorring then maybe its time to take your hearing aid into your local hearing aid repair and let them solve the whole issue with why it keeps shutting down
Jan 19, 2010 | Sonic Health & Beauty
I have an audifoon loon hearing aid and the battery was put in the wrong way, it is stuck how do I get it out.
You might try a dab of cooking oil around the battery door. Then try prying off the door with an eye-glass screw-driver. If this don't work, you might contact your hearing-aid dealer. I have an Oticon hearing-aid, and I made a similar mistake recently, but I got it done without any problem.
Sep 16, 2009 | Health & Beauty
Changed hearing aid battery left ear...now I cant hear with left hearing aid
Is it whistling when you hold it? Is the battery in the right way? Is it switched on?
Jul 06, 2009 | Health & Beauty
Trouble changing hearing aid batteries
i'm not aware of a tool to change batteries but Eveready sells hearing aid batteries that have a magnet on it so that you can put them in you aid easier. You can buy them at Walgreens ir CVS.
Apr 16, 2009 | Plantronics Dialogue Iiip Clarity...
Plantronics Dialogue Iiip Clarity Ameriphone Tty Machine With Printer Logo
988 people viewed this question
Top Plantronics Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Plantronics Health and Beauty Expert? Answer questions, earn points and help others
