Question about Welch Allyn Mobile Stand for Spot Vital Signs Lxi
HRM Support What is the first steps I need to take if I want to start training with a heart rate monitor?
    President:
  • 2,712 Answers
There are five easy steps you should take: 1. Roughly estimate your maximum heart rate (MHR) by subtracting your age from 220 (or a little more accurately, 214-(0.8 x age) for men, and 209-(0.9 x age) for women. If you're a regular runner, you can test yourself for your MHR by warming up and then doing a combination of short, fast runs as follows, ideally on a treadmill: run as fast as you can, evenly, for three minutes, then rest with two or three minutes gentle running, then repeat your three-minute maximal run; at some stage during the second effort you should get a higher MHR value than with any other method. 2. Work out your training zones: 50-60 per cent of maximum for easy recovery runs; 60-70 per cent for basic weight management; 70-80 per cent for aerobic training; and 80-100 per cent for threshold runs and speed training. The figures are more accurate if you find percentages of your working heart rate, then add them to your resting heart rate. You find your working heart rate by subtracting your resting heart rate from your maximum. 3. If you don't already have a training schedule, plan your runs for the week ahead and allocate a target heart rate zone for each run. 4. Stick to these zones. 5. Be alert for unusual readings. If you're ill, tired, stressed or not fully recovered from a race, then your resting heart rate may be higher than normal. If it's 5-10 beats above normal, make your day's run an easy one. Any higher than that and you should definitely have a rest day.
Posted on Aug 27, 2008
Watch turns self off after disconnect from HRM belt. After a few hours comes back on again by itself and have to reset up time date etc.
RTM. Read the manual. You can always do a google for your watch name make model and manual and you should get a .pdf to download and read it. It is a heart rate monitor so that heart should be on there.
Dec 01, 2014 | Timex Ironman Triathlon Heart Rate Monitor
I just received a brand new Garmin FR 60 with HRM monitor strap and ANT USB from Amazon. I followed the directions to use the strap[wet the electrodes, strap it over my chest, with the Garmin logo facing...
navigate using mode button to enter into watch's menu tree for settings/ sport/ run/ heart rate and turn on the heart rate monitor to hopefully detect and scan for the garmin ant+ protocol heart rate strap!
Sep 22, 2011 | Watches
I haven't used my Garmin Forerunner 305 for over a year - but have just started using it again. It wasn't picking up my heart rate from the HRM, so I changed the battery in the HRM but it is still not...
I found this on the internet......
In the battery compartment there’s a gold contact that touches the top of the battery (+ve) which was in a position that would never make contact with the battery. I bent it out slightly, made sure the battery was seated correctly (i.e. flat) and as if by magic my heart rate appeared on the large Garmin display!
Also found this..........
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80
Hope this helps......
Feb 09, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin 405 pair to wrong HRM
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80)
Jan 04, 2009 | GPS
Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Dec 12, 2008 | Timex Ironman Triathlon Heart Rate Monitor
HRM troubleshoot
A HRM is a training tool that helps you do cardiovascular (CV) training correctly, neither too hard, nor too easy. It’s almost like having a personal coach on your wrist! Every HRM comes in two parts: 1. An elasticated chest strap which contains a pair of sensors that detect and transmit your heart rate. 2. A wrist worn receiver that receives the signal from the chest strap and displays your heart rate. The receiver may also have additional functions and display other information depending upon the HRM model chosen. Both the chest strap and receiver are battery operated.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Monitor
Heart rate monitor support
Yes. If you're trying to lose weight, consider a HRM that provides information about calories burned. If you're just getting started, a simple heart rate only monitor is your best bet. They're easy to program and there are no buttons to push. If you're an athlete who enjoys competition, consider a HRM that provides feedback from your workout. These advanced HRM's memorize your workouts (heart rates, lap times and time spent in your THR zone) and allow you to monitor your progress.
Aug 27, 2008 | Probasics Digit-Ox Finger Pulse Oximeter
Heart rate monitor question
Price is always a consideration when it comes to HRM's. You can easily go to Target and purchase a $40 HRM, but consider the quality. Buying a HRM is an investment and you get what you pay for. You don't have to spend hundreds of dollars to get a high quality HRM, but you do want to make sure that it will last a long time. When buying a HRM go for trusted brands such as Polar, LifeSource, or Mio. Some of the cheaper models won't fit as snugly and may be heavier than higher quality brands.
Aug 27, 2008 | Haba Drive Fingertip Pulse Oximeter
Welch Allyn Mobile Stand for Spot Vital Signs Lxi Logo
257 people viewed this question
Top Welch Allyn Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Welch Allyn Exercise and Fitnes Expert? Answer questions, earn points and help others
