How should I measure my results?
The ultimate goal of training with a heart monitor is to be able to run longer and faster with a lower heart rate. If you keep track of your results, there will be a couple of ways to see the progress. First, as you improve, you will see that running the same distances at the same heart rate will become easier. Effectively, you will be able to run faster for these distances without your heart having to work as hard. This is a direct reflection of increased efficiency of the heart. To see this, try running a set course - with your monitor - that is several miles long, and stick to a preset speed, perhaps your marathon pace. Then, under similar weather conditions, try the same course again a few weeks later. Run it at the same pace as you ran previously, and compare your heart rates for the two runs. If you've gotten fitter since your first run, your heart rate should be lower during your second. Another way to see results is to keep track of your resting heart rate by taking it down and recording it every morning before you get out of bed. Many trainers recommend that runners keep track of their RHR on a daily basis, and, as stated above in the RHR section, increased fitness should bring with it a lower RHR.
