Question about Detecto 8450 Low Profile Digital Pediatric Baby Scale, 44 Lb X 0.02 Lb / 0.01 Kg / 0.5oz
Fat percentage question
What is the best fat percentage for me?
Averagely you need to eat right and make sure you take fruits, you can get more tips on Fat Loss Manual
Posted on Feb 04, 2011
How ot program body fat analyzer & scale
Posted on Jan 07, 2009
    President:
  • 2,712 Answers
Some body fat percentage levels are more culturally valued than others, and some are related to better health or improved athletic performance. Ideal percentages are also based on age categories as well. The recommended amount for women is 20-25% and for men is 8–14%. You can find a more detailed body fat percentage chart at your local dietitians and nutritionists, and on the internet.
Posted on Aug 27, 2008
How do I reset my Health O Meter BFM588DQ-81?
If the scale is moved, you must reset the scale back to zero in order to get an accurate reading.
Jun 11, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Is there an 800 number to call?
Health o Meter Brand Customer Service
1-800-672-5625
Jun 02, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Percentage error
how do you set up a problem when performing percentages ?
Jan 20, 2014 | Health & Beauty
I can get my bmi to work......it always displays E4..WHAT IS IT
E4 smeans The values of body fat percentage and BMI are outside the measurable range.
Please check and set height, weight, age, and gender again.
hope this help
Sep 08, 2010 | Omron Body Fat Analyzer from
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
E3 Error
here are the codes i found
E-1 Electrodes were not firmly grasped. Grasp the electrodes correctly.
E-3 Hands are dry. Slightly moisten hands with
a wet towel.
E-4 Body Fat Percentage and BMI values are outside themeasurable range. verify your personal data is
correct.
E-5 and E-6 Irregular Operation Turn the unit off, then on. Take another measurement. If the error occurs again contact Customer Service at 800-634-4350
have a great weekend!
Jan 29, 2009 | Omron Body Fat Analyzer from
Body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
Aug 27, 2008 | Detecto DR150 Low Profile Digital Platform...
How do I get body fat help?
The scales don't tell you the whole picture - your weight is less important than your percentage of body fat when it comes to appearance, fitness, and health. Tracking your percentage of body fat better shows how you are doing with diet and exercise than measuring weight. Remember that weight is measuring not only your fat, but also you muscles and your bones. If you did some extra work at the jym, your body weight might be effected (muscle tissue is heavier then fat tissue).
Aug 27, 2008 | Detecto Portable Digital Visiting Nursing...
Detecto 8450 Low Profile Digital Pediatric Baby Scale, 44 Lb X 0.02 Lb / 0.01 Kg / 0.5oz Logo
282 people viewed this question
Top Detecto Health & Beauty Experts
Louis Smith
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you a Detecto Health and Beauty Expert? Answer questions, earn points and help others
