Question about Detecto 253 Baby Scale Mechanical Infant Scale
Digital scale question
How do digital scales calculate body fat?
    President:
  • 2,712 Answers
Digital scales purport to measure your body fat through a process called BIA, or bioelectrical impedance analysis. Essentially, it clocks the speed that electricity travels through you. The scale runs a low-level electric current through your body, using your feet as positive and negative electrodes. The current encounters different levels of impedance, or resistance, from fat versus muscle. The scale measures this impedance, and throws it together with other factors (age, sex, height) to come up with your BMI, or body mass index.
Posted on Aug 27, 2008
    Problem Solver:
  • 6 Answers
In fact, every day looking at known words, will be very anxious, as well as a Monday times, so there is a sense of achievement
I think to lose weight on their own, is necessary for the movement.
Believe in yourself.
Posted on Jul 27, 2011
2 Suggested Answers
  • 2712 Answers
SOURCE: body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
Why is my body fat and water scale model 3015 not pairing
Your water scale model 3015 algorithm forgot to calculate for your bone density.
May 30, 2014 | Health & Beauty
ERR12 AND16 KEEP COMMING UP NEW SCALES unable to reset
Err 12 Inital load is too high power on zero point outside permissible range
Err 16 No zero point available, unable to calculate weight
Check no load on platform
Check the sensor this could be defective. This is the most likely
Sep 02, 2010 | Seca 354 Digital Baby Scale Pediatric...
I just purchased a Healthometer Weight & Body Fat Monitoring Scale. I successfully setting up my scale, I think? When I turn the scale on and weight for the 0.0 to appear, I get on the scale and it...
These scales use sensors to measure the electrical resistance of the human body to calculate body fat. If you are not stepping on the scale barefoot then that might be the reason why it is timing out. These scales require you to step on it barefoot so it can take a measurement through your feet. And using the height and gender information in combonation with the resistance measurement it can calculate your approximate body fat precentage. If you are stepping on the scale barefoot then make sure that your feet are properly placed into the sensors and avoid any movement. Let me know if you have any questions.
Feb 06, 2010 | Health & Beauty
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
BF% is wrong
Unfortunately, it's the scale, but it's not broken. It simply is telling you inaccurate information.
Some scales utilize Bioelectrical Impedance Analysis (BIA) technology. BIA uses very low levels of electrical impulses running from one metal contact point/lead to another. Your body acts as the connector between the two contact points, thus completing the circuit. Not all scales use this means for calculating body fat percentage due to poor reliability and high fabrication costs.This method of measurement requires very large contact points, as well as clean and moist skin exposure. If you have dry/calluced feet, which is normal for most Americans, the sensors can not accurately measure due to skin resistance. Dry skin acts as a resistor to electrical impulse. Electricity passes through muscle and fat at different rates. However, its measurements may be thrown off by how hydrated you are and how much you've eaten; it may be too inaccurate for anything other than comparative use. Users are encouraged to establish a baseline measurement and repeat measurements under consistent conditions over time to detect changes.
Many less expensive models simply use a body-fat calculator to average your imputed height in inches, waist measurement in inches and the current weight measurement recorded in lbs. The scale compares your measurement with the ideal norms inputed during the manufactoring process, thus giving you a comparison vs.imputed norms. People who are very, very fit can get numbers 3 to 5 percent higher than their true percent body fat. Because they don't have a lot of fat inside their muscles(visceral fat), the simple tape measure calculation test cannot adjust as it should indicate.
Conversely, if a person is skinny but not fit, this body fat test may yield a number 3 to 5 percent lower than his or her true percent body fat. Though they look thin, unfit skinny people really have more than the usual amount of fat inside their muscles, which you can't see from the outside.
In either case, the scale is not necessary a measurement tool, due to high variables of test inaccuracy and interuser reliabilty; but, it is a good tool for comparing whether or not you are gaining/losing body fat.
If you would like a more accurate tool for simply measuring your body fat, you can pick up some pinch-calipers online for about the price of a scale. They come with an instructional pamphlet, very easy to use.
Jan 13, 2009 | Conair Weight Watchers WW-87 Body Fat...
Body fat scale Question
Aug 27, 2008 | Detecto DR150 Low Profile Digital Platform...
How do I get body fat help?
The scales don't tell you the whole picture - your weight is less important than your percentage of body fat when it comes to appearance, fitness, and health. Tracking your percentage of body fat better shows how you are doing with diet and exercise than measuring weight. Remember that weight is measuring not only your fat, but also you muscles and your bones. If you did some extra work at the jym, your body weight might be effected (muscle tissue is heavier then fat tissue).
Aug 27, 2008 | Detecto Portable Digital Visiting Nursing...
Detecto 253 Baby Scale Mechanical Infant Scale Logo
501 people viewed this question
Top Detecto Health & Beauty Experts
Louis Smith
Rhonda Webster
Rhonda Webster
swetha
swetha
Are you a Detecto Health and Beauty Expert? Answer questions, earn points and help others
