Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
LCD brightness question
How Do I Adjust The LCD Brightness Or Color On My SC-D103 Or SC-D107?
    Master:
  • 473 Answers
You can adjust the brightness or color of the LCD display as needed. 1. Set the POWER switch to CAMERA position. (In the PLAYER mode, you may only setup the LCD while the tape is playing.) 2. Open the LCD screen, and the LCD switches on. 3. Press the MENU button. 4. Turn the MENU DIAL so that VIEWER is highlighted and then press the ENTER button. 5. Turn the MENU DIAL so that LCD ADJUST is highlighted. 6. Press the ENTER button to enter the sub-menu. 7. Turn the MENU DIAL so that it highlights the menu item you want to adjust (BRIGHT SELECT, BRIGHT ADJUST, COLOR ADJUST). 8. Press the ENTER button again. You may select NORMAL or SUPER in the BRIGHT SELECT feature and press the ENTER button to save the setting. Use the MENU DIAL to adjust the value of BRIGHT ADJUST and COLOR ADJUST. You can set values for BRIGHT ADJUST between 00 ~ 35 and COLOR ADJUST between 00 ~ 35. 9. Press the MENU button to finish the setting.
Posted on Sep 06, 2005
Can't adjust the color, brightness or contrast so that there is a pure white color. Can this be fixed?
yes you can. Go to Menu, and follow the steps for adjust the color, brightness ,etc or restore the factory default in Menu
God bless you
Jul 31, 2013 | IBM ThinkVision L170 17" LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
How to adjust brightness
The set should have in the on screen customer menu settings for brightness, contrast, color, tint etc.
If in doubt consult the owner manual which will have instructions.
Aug 29, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Acermointors color is to bright
try to adjust front panel button, for the brightness control + - sign, if not function the problem is the lcd ckt. and need service.
Mar 25, 2010 | Acer 22" X223w LCD Monitor
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
DIM LCD
TWO WAYS TO TURN IT UP
1. Use the menu on the monitor to turn up the volume
2. right click anywhere on the desktop- select properties - select the "settings tab" at the top - click on the "advanced" button. this will open your video cards display settings .
you will need to look for a brightness controll or color corection section to adjust the brightness as all video cards have different software for controll.
Gamma will increase you brightness also. a ballance od gamma and brightness is neccessary, so change em both small amounts , then check your desktop or applications, then re-adjust.
This should Fixya up ! Please rate.....
Oct 28, 2008 | Computers & Internet
Ibm thinkpad 600x brightness control
There is no otherway. becase the slides sends direct signal to inverter for adjusting brightness. You can adjust brightness the
other way ,through graphic cards property, but that is only adjustment for the color and if you do make it bright, you'll be loosing the vivid color..not so natural.
takecare.
Apr 19, 2008 | IBM ThinkPad 600X Notebook
LCD problem...
Most of our camcorders have an option to turn the LCD brightness up or down but not to turn the LCD off. If the brightness is turned up and the LCD will not turn on, the battery may be very low, or the unit may require service. The following Articles provide model specific instructions for making LCD adjustments. The majority of Samsung archived camcorders use the same instructions as the article for the SC-D103/SC-D107.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
579 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
