Question about Haba MDF Thigh Single Tube Latex Free Blood Pressure Cuff, Color Purple Rain
Cuff position How do I put the cuff properly on my hand?
  • herb30 Apr 24, 2009
    The question was how to properly put the WRIST cuff on, not the upper arm in the answer.
    President:
  • 2,712 Answers
An upper arm monitor will come with a cuff that you need to wrap around your arm. If you use a cuff that is the wrong size for you, your reading will not be correct. Measure around your upper arm at the midpoint between your shoulder and elbow. Most monitors will come with a medium sized cuff. You may have to order a different sized cuff separately.
Posted on Aug 27, 2008
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
Mod hem 704c reads high compared to doctors blood pressure readings
There are many things that can affect the readings. Cuff size is one of the biggest. If the cuff is on the small side it will not read as accurately as a cuff that fits properly. Keeping the cuff at heart level is important as well. Many people have to put the cuff lower on the arm if the cuff is too small and then they don't raise the cuff to heart level. This will give a higher reading. What is most important is to ensure that the readings are consistent. While they may be higher than the doctors office, as long as they are not dangerous, use them as a baseline and monitor fluctuations over time to ensure that your medications are doing their intended work.
Feb 15, 2016 | Health & Beauty
Why does anOmron M7 Blood Pressure Monitor Cuff not fully inflate?
I have the BP760 model so I'm not entirely sure what the functionality differences would be. However from time to time I have had issues with the cuff not inflating. It is usually one of two things: the cuff is not positioned snugly enough on the arm (I have a skinny arm and sometimes need to enlist the help of a family member). The other time it has happened was when the inflation tube itself with so kinked and twisted that air could not flow through. You should also check to make sure that the inflation tube in securely connected to the unit. So make sure that the air supply from the cuff to the unit is not obstructed, and that the arm cuff is positioned properly and that you are not trying to put the cuff on over clothing. If you've checked all of this and/or you receive the error message of "Er", you should contact customer service. Hope this helps.
Aug 29, 2014 | Health & Beauty
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
Morning! I have a bpa 300 nearly new lost receipt shows EE everytme iwas wondering if you have any solutions thanks K wilkinson
Generally the EE error code stands for the following:
EE is a measurement symbol for one or more of the following;
  • Cuff has been placed incorrectly. Wrap the cuff properly so that it's positioned properly on the wrist. 1" above the heel of the hand.
  • Talking or movement during measurement. Shaking of wrist with the cuff on. Measure again, keeping the wrist steady and at heart level during measurement.
  • The value shown on the display is excessively Low or High. Wait 5 minutes and measure again.
Hope this helps you. If you continue to have a problem with the monitor contact HoMedic's Customer Support 800-466-3342. As most of their BP Monitors have a 5 year warranty.
May 16, 2011 | Homedics Bpa-300 Deluxe Auto Blood...
I have a cuff like this and get an error saying EE
According to the Owners Manual, the EE Message shown on the display or the blood pressure value is displayed when an excessively low (or high) reading is detected OR as a result of one of the following:
1. Cuff has been placed incorrectly. Solution: Wrap cuff properly so that it's positioned correct.
2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady at heart level during measurement.
3. Shaking or moving of the wrist with the cuff on. Solution: Same as # 2.
NOTE: Be sure the cuff is placed exactly as pictured on the face of the box, 1/2" above the heel of the hand.
Jan 27, 2011 | Walgreens By HoMedics Automatic Wrist...
What does EE mean?
EE means one of 3 things:
1. Cuff has been placed incorrectly. Solution: Wrap the cuff properly so that it is positioned correctly.
2. Did you talk or move during measurement? Solution: Measure again. Keep wrist steady during measurement.
3. Shaking of the wrist with the cuff on. Solution: Same as # 2.
Jan 25, 2011 | Walgreens By HoMedics Automatic Wrist...
How do i fold down the mutsy urban rider pushchair
To fold the Mutsy Urban follow these steps:
Stand slightly to the left of the pram, but have the handle bar (with button depressed) in your right hand. Have your left hand on the black cuff (on the left hand leg of the chassis)
In one movement, push in the button on the handle (with your right hand) and move downwards, whilst pulling the cuff upwards (with your left hand). Do this quite firmly and the pram will then collapse. Make sure that the handle is in the lowest position after folding, ensuring that the pram is as small as possible.
I hope this helps.
Jul 04, 2009 | Baby Gear
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
Feb 07, 2009 | Omron Automatic Blood Pressure Monitor...
Haba MDF Thigh Single Tube Latex Free Blood Pressure Cuff, Color Purple Rain  Logo
642 people viewed this question
Top Haba Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Haba Health and Beauty Expert? Answer questions, earn points and help others
