Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
Deleting Photos From The Memory Stick
Hoe do I delete pictures from the memory stick?
    Master:
  • 473 Answers
Deleting Still images From The Memory Stick This procedure is nearly identical with all of our digital camcorders. The only difference you may find is that there may not be an enter button on your model. If this is the case, the menu dial serves as your enter button when you push it in. * If you want to delete protected images, you must first deactivate the image protection. * An image which has been deleted cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. 3. Using the (FWD) and (REV) buttons, search for the still image that you want to delete. 4. Press the MENU button. 5. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The MEMORY SET submenu will appear. 6. Turn the MENU DIAL to highlight DELETE and press the ENTER button. Using the MENU DIAL, select either THIS FILE or ALL FILES and press the ENTER button. *THIS FILE : deletes only the file currently selected. *ALL FILES : deletes all files stored in the Memory Card. 7. A box will appear to verify whether you wish to delete the image(s). Using the MENU DIAL, select the item. *EXECUTE : deletes the selected image(s). *CANCEL : does not delete the selected image(s) and returns to the previous menu.
Posted on Sep 06, 2005
SOURCE:
Can't delete data off USB stick
SO YOUR OFF USB STICK IS NOT DELETING YOUR MEMORY CARD MUST HAVE DOING SOME OPERATIONS PRESS CTRL+ALT+DELETE THE DALOG BOX WILL APPEAR GO TO PROSSESS AND STOP THAT PROCESS
Mar 31, 2013 | Electronics - Others
How to delete pictures on my memory stick pro duo
If you computer has a slot for it, plug it in and use windows to erase what you want. Otherwise try using a camera or another device that accepts sony memory cards.
Jun 20, 2012 | Sony Electronics - Others
My camera tells me it's full when it shouldn't be. I have a 2gb sony memory stick pro duo for my Sony Alpha 100 camera. Today, I shot about 80 photos and it said it was full, but I had just deleted all...
hi, sometimes old photos tend to stay inside due to some defect or settings. instead of deleting photos. format the card once before you start clicking the photos. formatting can be done in PC or in your camera. if this does not solve the problem. please revert back to us. thank you. sweet rascal
Oct 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
No memory space in memory stick
Transfer the images from the memory stick to your computer, make sure the transfer has been successful so you don't lose your pictures, then to be safe put the stick back into the camera and delete them once back in the camera. AGAIN, before you delete anything, make sure your pictures have been safely transferred to your pc and you can view them all. Deleting the photos from the stick will make the disc empty again and ready for more shots to be taken.
Jun 08, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Fuji FinePix Z10 pictures will not add to memory stick
After reading the manual, it seems if you delete any pictures directly from your computer with your memory stick loaded into the computer, then you corrupt the memory stick. I usually use a USB cord, but not this time. So with that said. I need to buy a new memory stick. I will only delete pics directly from the camera from now on. It is not a camera issue, more of a "not knowing" issue.
Mar 26, 2009 | Fuji FinePix Z10fd Digital Camera
Deleting all pictures from my Memory stick
go to the setup menu (I think if you press the Menu button) and select the memory stick tool then select format.
Oct 24, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Importing data from stick to computer - deleting data on stick
Yeah, all you have to do is delete all the pictures on the card. It's easiest to do on your computer, not the camera. Just put the memory stick back into your computer and find all the pictures and select and delete them. If you've already transfered them to your computer then don't worry about it. If you delete the photos off the stick, they will NOT be deleted from your computer so just go ahead and do it.
May 24, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick - delete all photos
Need to delete pictures of a Sony Cybershot DSC_W90 and can't find book. Need help
May 15, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Deleting pics from memory stick
Option Go to list of pictures and check any menus like(mark ,mark all.delete all ) if have option mark menu -just mark all pictures and select delete. opton
2 if you have mark all -just -mark all -and delete
3.if you have delete all -just -delete all -it will delete all of your pictures in memory card
IF NOT OK
IF YOU REALLY delete all pictures and all datas
4.if you wish to do Formate the memory stick
now your Memory stick has Empty.
May 15, 2008 | Sony Part 996804671 Service Manual for...
Sony cyber-shot dsc-h2
hi,
Its simple..
After connecting USB to the laptop, a window will appear.
In that window, "select files to open".
It will open the DCIM.click and open the DCIM folder you wil find 101MSDCF folder.(for e.g.F:\DCIM\101MSDCF)
Select and delete all photos.
I did the same and i was able to get back memory.
I dont know whether its standard way of deleting photos from memory stick. Any support guys from sony camera can comment on it....
thanks
Apr 12, 2008 | Cameras
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
243 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
