Question about CARE Devilbiss 800C Pediatric Reusable Nebulizer
RESPULES Question Can PULMICORT RESPULES be used in any type of nebulizer?
  • 2,712 Answers
No, PULMICORT RESPULES should only be delivered through jet nebulizers. Jet nebulizers are the only effective device for delivery of suspensions such as PULMICORT RESPULES. Because of their physical characteristics, suspended drug particles are generally poorly nebulized in ultrasonic devices.
Posted on Aug 27, 2008
  • Amanda Hoff
    Amanda Hoff Oct 24, 2013
    What about the vibrating mesh unit? it's not ultrasonic, but it's not a jet. We've been doing it, and it seems to be working fine, but want clarification. Thanks.
Hi, in my phone network is not found& sim regstation is faild notes is display
Posted on Jul 29, 2011
How to put the solution and the ventolin on a Ne c 28 _e
open the container with the screw type which is connection to pipe .and fill the medicine
Apr 13, 2011 | Omron Compair Compressor Nebulizer System...
Compressor works ,but does not put out enough pressure to make a mist from the pulmicort 5-1/2 years old used 2 times a day
You probably need a new diaphragm in the pump. Contact your insurer, they might replace the entire unit for you. In a pinch, you can use a vibrating style fish tank eirator pump, since there isn't any real positive pressure coming out of the facepiece.
Oct 12, 2009 | Inspiration 626 Compressor Nebulizer...
My husband was told to mix Pulmicort Respules 0.5mg/2mL and brovana 15mcgi2mL twice a day. Is it safe.
Mar 17, 2009 | Cardinal Pediatric Nebulizer Aerosol Mask,...
Parts on the Pink car Nebulizer
The funnel is called a "diffuser". It just sets inside the measuring cup and will gently vibrate during a treatment to ensure all the medication runs off the sides the cup to be atomized. You can also ask your family Dr. to review the set up with you if you are concerned that you are not using it right.
Dec 31, 2008 | Drive Medical Checker Nebulizer Yellow - 1...
Need to have a copy of the manual for a devilbiss pulmo-aide 3655
The long tubing should have a green end and a blue end. (If both ends are the same it does'nt matter) Now the little cup that holds the medication...look at the bottom of the cup. It should have a male connector (blue or green) take the end of the tubing that matches the color of the male connection and firmly plug them together. Hold the chamber/cup upright. If your unit has a little plastic diffusor, drop that inside the chamber. now locate the top af the chamber and screw it on. You should have a large whole the size of a nickle on top. This is where you squeeze the medication in. After putting in the medication put the mask(or mouthpeice) Firmly into the place where you put the medication into....and your peices should be assembled. Last thing is to plug the other end of the tubing into the machine itself and then turn on the power.
Dec 18, 2008 | DeVilbiss Pulmo Aide Compressor Nebulizer
Nebulizer portion is accumulating what appears to be saliva
well i have a inhaller tube to and yes it can be straight and it can slope down too. saliva no it's not possible but it could run down your cheek. or you could go and ask where ever you got the nebulizer from
Dec 01, 2008 | RTO Spider Nebulizer
No, PULMICORT RESPULES, when mixed with other nebulized medications, has not been adequately assessed. PULMICORT RESPULES should be administered separately in the nebulizer.
Aug 27, 2008 | Cardinal Pediatric Nebulizer Aerosol Mask,...
Nebulizers problem
There are two main types of nebulizers: jet and ultrasonic devices. Jet nebulizers form droplets by using a compressor to deliver a pressurized jet stream of air down a narrow tube and through an opening. This creates a vacuum (through the Venturi effect), thus drawing liquid from a reservoir. The resultant small droplets of liquid are propelled out of the machine by the continued jet stream. Ultrasonic nebulizers produce aerosolized droplets using high-frequency sound waves generated by a special crystal. Liquid drug is usually delivered to the crystal, where it forms a thin layer. Electricity excites the crystals, causing them to vibrate at extremely high frequency. This vibration forces the thin liquid layer through an adjacent mesh, creating a fine mist. Droplet size varies with the frequency of the sound waves created by the vibrating crystals.
Aug 27, 2008 | Cardinal Airlife Brand Modudose 5 Ml Unit...
CARE Devilbiss 800C Pediatric Reusable Nebulizer Logo
408 people viewed this question
Top CARE Health & Beauty Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a CARE Health and Beauty Expert? Answer questions, earn points and help others
