Question about Campbell Hausfeld MIG / Flux Core Wire Feed Welder
Square Wave Question
What is Square Wave?
  • 2,712 Answers
Square Wave refers to the shape of the voltage cycle in a welding arc. In an AC wave, a typical sinusoidal or sine wave, changes the voltage from positive to negative gradually, although many times a second. This means the voltage will not be consistent and at times will actually go through zero. Square Wave, on the other hand, changes the voltage from positive to negative almost instantly, making for a much smoother and more stable welding arc. This is particularly important when welding aluminum and when considering aspects like cleaning and penetrating action.
Posted on Aug 27, 2008
What is the function of a hall sensor G40(Camshaft position sensor)
Hall sensor function
A hall effect sensor is a sensor that produces a square wave output that can be directly read and modulated by the ECM (as opposed to an AC wave sensor which produces a sine wave that must be converted). They are used as cam position sensors and ABS wheel speed sensors.
Hall Effect Sensor and How Magnets Make It Works
Apr 18, 2017 | Cars & Trucks
Where is the VSS is located on a 2004 SRX?
Inside the transmission , pull the pan ! It's the out put speed sensor.
The A/T OSS sensor is a variable reluctance magnetic pickup located in the rear of the transmission case. The sensor is mounted in the case (24) opposite the rear internal gear (560). The rear internal gear is splined to the output shaft assembly (562). The sensor consists of a permanent magnet surrounded by a coil of wire. As the output shaft and rear internal gear rotate, an alternate current (AC) is induced in the coil by the 'teeth' on the rear internal gear as they pass by the magnetic pickup. Therefore, whenever the vehicle is moving, the A/T OSS sensor produces an AC voltage signal proportional to vehicle speed.
At the TCM, the AC signal is electronically converted to a 5 volt square wave pattern. The square wave pattern can then be interpreted as transmission output speed by the TCM through the frequency of square waves in a given time frame. The square waves can be thought of as a representation of the rear internal gear teeth. Therefore, the more teeth or waves that pass by the magnetic pickup in a given time frame, the faster the vehicle is moving. The square wave pattern is compared to a fixed clock signal internal to the TCM to determine transmission output speed. T
Oct 19, 2015 | 2004 Cadillac SRX
Grundig lcd tv standby stuck
Inverters use square wave voltage, which tends to stifle digital circuits. Leaving something stuck, or not working. Sure, the inverter will work for awhile, but then the rigid square wave eventually causes problems.
Feb 02, 2014 | Polaroid Televison & Video
Tv dosent respond to remote when powered by inverter
Inverter is square wave. Square wave interferes with digital circuits sometimes.
Jan 18, 2014 | Televison & Video
Wave ceptor 106 instructiuni de reglaj
take number off back, in little square 4 digit number , and go to casio website, look up tab manual archives. . put in number , download it.
Jun 18, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I am using square wave unregulated ups for tube lights and fans when it is on load momentary output goes off then on during running i check batteryfan clean with blower but problem still present.
If this problem exists when the load is first applied you are probably having an over-load condition as the sudden inrush of current is more than the ups is rated for. Square wave ups are bad about this.
Jun 30, 2010 | Computers & Internet
Have a lincoln square wave 175 tig maching with
buy a Cobra lead and torch head already equiped would be you best bet.
Nov 13, 2009 | Welding Tools
Whirlpool GH6177XPS G2 Microwave
Your generator may be putting out a square wave instead of a true sinusoidal (sine) wave.
There is usually a circuit in the microwave which monitors the AC line for timing purposes, and a square wave may not be interpreted correctly.
I would consult the manual or contact the manufacturer or installer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 08, 2008 | Whirlpool GH6177XPS Microwave Oven
Campbell Hausfeld MIG / Flux Core Wire Feed Welder Logo
170 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
