Question about Radnor A35HP 350A Water Cooled 25' TIG Torch Package
TIG MIG Difference
What is right for me, MIG or TIG?
    President:
  • 2,712 Answers
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Posted on Aug 27, 2008
    New Friend:
    Problem Solver:
  • 5 Answers
MIG welding is very fast, you can make a lot of welds per hour, for example if you are building a boat MIG it is ideal.
TIG welding is very precise but slower compared with MIG welding. Excellent for thin metal. If you are building a bike Tig will work best.
Posted on Nov 13, 2016
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
I have a mishto 220 mig tig mma I can get the arc to work fine but the mig there's no arc at all the machine sounds like its welding but no arc at the gun I'm using gassless wire I thought it may be an...
They told me at welding school the mig transformer has a different slope (whatever that means?) to the tig and mma transformer so I am a little surprised at your question. The implication is two transformer are needed for the three types of welding and for tig and mig a dc converter and also for dc mma welding.
From your description it seems as though welding current is not arriving at the tip of the mig torch or the current is arriving in the wrong form.
You say the mma is fine but you didn't say whether it is fine on ac welding, dc welding or both. I have not tried mig welding with ac and have no idea whether it would be successful but I imagine a lot of sparks and not much welding. The problem could be the rectifier unit is either not working or is switched out of the circuit.
Polarity is important too with dc tig and mig welding.
I hope this provides food for thought.
Feb 04, 2015 | Welding Tools
Hi I need a cobel mig/tig/arc welder wiring diagram can anyone help
Have you joined the Cobel/ Mig Weldin Forum? There are a few videos on youtube but I dont know your model so I did not post a link. But try the forum first.
Jan 30, 2015 | Welding Tools
What is TIG and MIG wielding?
Both are different wielding methods used in metal fabrication service. Tungsten inert gas wielding or TIG is high quality arc wielding and is used for high quality wielding applications. Metal inert gas or MIG is another form of wielding.
Jun 10, 2013 | Welding Tools
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Have a CT-200 Hobart Welder Getting high frequency but no current?
Sounds like the problem could be with your tig torch. Inside the tig torch you have a copper cable which carries your main welding current. If there is a break in the copper the high frequency is of such a high tension voltage that it can jump across the break in cable making it appear that your tig torch is fine. If you have a multimeter check continuity from one end of the torch to the other or try another tig torch.
Nov 06, 2011 | Hobart Handler 140 Mig Welder
What is the basic technique in welding
Hi:
Well don't know were to start, basic technique goes according with the type of metal to weld and type of wire to use.
I think if will be better if you read the basics of welding with MIG machines with an owner's manual. Check the link and go to section B-7.
http://www.lincolnelectric.com/assets/servicenavigator-public/lincoln3/im564.pdf
Sep 13, 2011 | Welding Tools
Tig Welding settings for Renrgade 160VRD welder
Your machine is a MIG welder only. You can't do TIG. Sorry.
Dec 25, 2010 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Mig problem
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
How to TIG Weld
TIG stands for Tungsten Inert Gas welding. Also called GTAW (Gas Tungsten Arc Welding) and Heliarc® which was Linde's trade name for the TIG process when it was introduced many years ago. The arc is started with a tungsten electrode shielded by inert gas and filler rod is fed into the weld puddle separately. A slower process than MIG, it produces a more precise weld and can be used at lower amperages for thinner metal and can be used on exotic metals. TIG does require quite a bit more time than MIG to learn. It is similar in technique to gas welding.
Aug 27, 2008 | Radnor Model 105Z55 Push On Smooth TIG...
Radnor A35HP 350A Water Cooled 25' TIG Torch Package  Logo
1,093 people viewed this question
Top Radnor Welding Tools Experts
Bill Boyd
Are you a Radnor Welding Tool Expert? Answer questions, earn points and help others
