Question about Allegro Lomi Lomi Personal Massager
Battery charge On the rechargeable models, how long usually it takes to recharge the battery entirely?
    President:
  • 2,712 Answers
The charging time is different between every product and product. Usually, the standard charging time is 5 hours (full charge). A full charge will give youabout 40 minutes of cordless use.
Posted on Aug 27, 2008
Big blue speaker repair
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
If the speaker is under warranty get it replaced.
Taking the speaker apart to replace the battery will compromise or even destroy the acoustic properties of the speakers. Big Blue Live Wireless Bluetooth Speaker
Mar 09, 2015 | Brookstone Big Blue Studio Wireless...
My pendo wont fully charge, and now it won't come on at all
Feb 23, 2015 | Tablets & eReaders
My tablet will not power on & shows no signs of charging
Feb 22, 2015 | Tablets & eReaders
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Kobo not accepting a charge
Jul 28, 2014 | Kobo Arc
No Power with or without battery
The device requires current compartment observations. Ascertain that bateries in compartment, cables wires are traceable to the outs, and that visible malfunct objects are least are unavilable. Perform recharge on computer devices to restore battery cell capacity. Usually depleted current requires full recharges to last an entire duration with every feature powered off to attain process. After ascertaining the restroation capacities, usually the devcie should power on after charging else the battery requires replacement an aletrnate as depleted completely.
Feb 13, 2011 | Computers & Internet
My camera will only turn on to take photos when its chargin.... if its not charging it wont turn on and its only 1 month old
There are a lot of Fuji digital cameras if "we" knew what model it was you would possible get more then just a guess. My guess is that the batteries (if it uses AA's) are either Alkaline type and dead on power OR if they are rechargeable they are not installed properly all it takes is one battery to be put in the wrong way and nothing works. The charger on some models can bypass the battery circuit to operate entirely on AC power and charge batteries at the same time. Check your batteries if they are Alkaline type AA's then you can't recharge them. Check make sure if you have rechargeable type that they are in correctly.
Jan 07, 2011 | Fuji Cameras
I own aB&D 14.4 Driver drill modelCD140G. Do I have to discharge
Newer rechargable batteries aren't like the older ones back from 5-10 years ago. They do not have a "memory" like old cell phone batteries and cordless tools used to have. So charge it whenever.
Stick it in the charger and when it's charged, the light will stop flashing. Usually takes a few hours for a full charge.
It's not recommended to leave it in the charger for extended periods. Not only does it siphon off your power bill, but it's harder for the battery I believe.
I've had mine for a few years and they done excellent. Just as powerful as the day i bought them.
If they ever do give out, be sure to recycle them, don't throw them away. Lowes and Home Depot have rechargeable battery recycling at the front desks.
Jan 21, 2009 | Black & Decker CDC140ASB 14.4-Volt Compact...
Printer will not charge camera batteries. camera screen said to go on line and look for m627-435
Did you go online and look up this troubleshooting tip from HP?  Did you make sure the batteries are rechargeable and in the correct orientation ( + and - )? Here is the results from looking up the error code M627-435 at the HP website:
Solution
  1. Ensure that the batteries are rechargeable. If the batteries are not rechargeable, replace them with rechargeable batteries.
  2. If the batteries are rechargeable, take them out and check for obvious physical damage. If the batteries are damaged, replace the batteries with rechargeable batteries in good physical condition.
  3. If the batteries are in good condition, charge the batteries using the external charger that shipped with the camera before using them in the camera for the first time.
  4. If you have tried each of the steps above and the status message still displays when you try to charge the batteries, replace the batteries.
Cause The Batteries cannot be charged status message is usually caused by one of the following:
  • When first connected to an optional HP AC power adapter or placed on an optional dock, the camera performs a test to determine if the batteries are rechargeable. If the test determines that the batteries are non-rechargeable, an status message displays in the LCD.
  • If the battery charge falls below 1.1 volts, the camera cannot detect that the batteries are rechargeable. The camera does not charge batteries below a 1.1-volt threshold to prevent charging non-rechargeable batteries. Rechargeable batteries discharged below 1.1 volts can be charged in an external charger.
    Apparently, your batteries are either seriously discharged where you need to use an external AC charger to recharge the batteries or their damagaed and need replacing. Hope this helps.
Oct 31, 2008 | HP Cameras
Allegro Lomi Lomi Personal Massager Logo
208 people viewed this question
Top Allegro Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Allegro Health and Beauty Expert? Answer questions, earn points and help others
