Question about Miller COOLMATE 3 115V TIG TORCH WATER COOLER 043007
TIG welder tips
Any tips for buying one?
Can be a big choice of sets. I spoke to our nearest welding supplier. They were very helpful. Try them. Britannia Welding Supplies Ltd, tel 01252-333661.
Posted on Dec 08, 2009
    President:
  • 2,712 Answers
Go to your local welding supply store. A TIG welder is a specialized welder that cannot be found at a building supply store. Stores like Maine Oxy-Acetylene Supply or Grainger Industrial Supply will carry them. Look in the classifieds of publications like Uncle Henry's. There you might find a TIG welder that someone is selling—and it may be at a good price. Be sure to ask the owner questions and take a look at the TIG welder before buying it. Explore eBay. Yes, even eBay has TIG welders. You'll need to ask the buyer questions about the welder's history and more. Perhaps, if the seller is near enough, you might be able to pick up the TIG welder yourself and save on shipping. Visit online retailers. Retailers like Welders Direct or Welding Mart carry TIG welders and would be able to answer any questions you might have (see Resources below). Consider the manufacturer of the TIG welders themselves. Lincoln, Miller, Hobart and others have their own websites. Call the companies directly and ask a lot of questions. These vendors are the best product source for welders (see Resources below).
Posted on Aug 27, 2008
2 Suggested Answers
SOURCE: Tig welder wont strike up arc, power to welder ok,
www.millerwelds.com › ProductsTIG -
www.millerwelds.com › Service & Support
Posted on Mar 27, 2010
GIANT WSE 200 amp ac dc tig welder
Buy a new circuit board as it will be cheaper in the long run as the solder has damaged vital parts on the board. It will take a lot of frustration in fixing all parts .
Apr 04, 2013 | Welding Tools
Tusten tip keeps sticking what am i doing wrong i have rockworth inverter
Make sure the tungsten tip is sharp, not too far from the nozzle and try not to let it touch the metal or molten pool. Also make sure you have an adequate gas feed
Feb 23, 2011 | Inverter 220 Volt Tig Arc Welder
Looking for plastic housing
Check with www.millerwelds.com they should be the ones who can help you.
Mar 30, 2010 | Miller Electric Manufacturing Electric...
Flux wire welder will spark but will not weld continuously
Clean the plate/sheet firtst then attach the earth ensure you have fitted the same size tip as the wire, check all the switches on the set that the are pointing for the conditions, If it is arc as well as TIG. there will be a little switch that you move for either TIG or stick welding .( could also give "LIFT TIG")
Jan 15, 2009 | Miller Welding Tools
I have a miller dynasty inverter tig welder   It has a help code that comes on when I turn it on the code is p-2
From the user manual for a generic dynasty model welder:
2 Help 2 Display
Indicates an open in the thermal protection
circuitry located on the left side of the unit.
Contact a Factory Authorized Service
Agent if this display is shown.
So you could have anything from a broken or disconnected wire to a bad thermal switch.
You can get user manuals specific to your welder at www.millerwelds.com
Rank this answer please,
Carl
Nov 26, 2008 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Tig welder suppot
Make sure the area around your welding surface is completely clear. This will prevent fires from starting.
Aug 27, 2008 | Campbell Hausfeld WT610000AV Tig Welder...
Miller COOLMATE 3 115V TIG TORCH WATER COOLER 043007 Logo
509 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
