Question about Campbell Hausfeld WT610000AV Tig Welder Torch Kit
Tig welder suppot
Any good safety tips?
    President:
  • 2,712 Answers
Make sure the area around your welding surface is completely clear. This will prevent fires from starting.
Posted on Aug 27, 2008
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
Tusten tip keeps sticking what am i doing wrong i have rockworth inverter
Make sure the tungsten tip is sharp, not too far from the nozzle and try not to let it touch the metal or molten pool. Also make sure you have an adequate gas feed
Feb 23, 2011 | Inverter 220 Volt Tig Arc Welder
The tig welder will arc but there is no amperage and nothing is heated up it acts l;ike there is no amperage?
Make sure you have a good ground. With high frequency you can get it to still arc but have a bad ground.
Jun 11, 2010 | Miller Hf 251D 042388 Tig Hi Freq For...
Looking for plastic housing
Check with www.millerwelds.com they should be the ones who can help you.
Mar 30, 2010 | Miller Electric Manufacturing Electric...
Giant inverter tig mma111 230 volt
check if the load on it is not more than its capacity and check the batteries if they are still in good condition
Nov 16, 2009 | Inverter 220 Volt Tig Arc Welder
Running tig and machine is not on pulse but it pulses then shows a help code 10
Sounds like a processor problem. Check with local welding supplier for a good service tech.
Oct 14, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Mig problem
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
TIG welder tips
Go to your local welding supply store. A TIG welder is a specialized welder that cannot be found at a building supply store. Stores like Maine Oxy-Acetylene Supply or Grainger Industrial Supply will carry them. Look in the classifieds of publications like Uncle Henry's. There you might find a TIG welder that someone is selling—and it may be at a good price. Be sure to ask the owner questions and take a look at the TIG welder before buying it. Explore eBay. Yes, even eBay has TIG welders. You'll need to ask the buyer questions about the welder's history and more. Perhaps, if the seller is near enough, you might be able to pick up the TIG welder yourself and save on shipping. Visit online retailers. Retailers like Welders Direct or Welding Mart carry TIG welders and would be able to answer any questions you might have (see Resources below). Consider the manufacturer of the TIG welders themselves. Lincoln, Miller, Hobart and others have their own websites. Call the companies directly and ask a lot of questions. These vendors are the best product source for welders (see Resources below).
Aug 27, 2008 | Miller COOLMATE 3 115V TIG TORCH WATER...
Campbell Hausfeld WT610000AV Tig Welder Torch Kit Logo
168 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
rjivaro
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
