Question about MILLER 212735 O-RING PLASMA CUTTER
Welding Question what is the differance between a welding torch and a plasma cutter?
    President:
  • 2,712 Answers
The plasma also cuts ferrous and non-ferrous metals much faster than an Oxy-Fuel torch or abrasive saws, with low or no heat affected zone, especially on thinner metals. A clean cut with little or no dross means less time and money is required to finish the work piece. Parts are virtually weld-ready
Posted on Aug 27, 2008
What is the limitations and benefits for a swan neck welding torch
Posted on Apr 24, 2013
2 Suggested Answers
  • 225 Answers
SOURCE: Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Posted on Apr 11, 2010
Torch doesn't have correct flame
Without knowing the specific torch tip you're working with and what you're welding/soldering the only thing any one can suggest is cleaning the tip. You can get welding tip cleaning files any where that sells welding supplies.
Dec 23, 2013 | BernzOmatic Welding Tools
Setting for welding aluminum
You have posted under a plasma cutter. These CANNOT weld metal, only CUT it.
Jun 04, 2010 | Lincoln Electric Century Portable Plasma...
Working on and off
if you have to tap the tourch to get it to work then something in the tourch is loose or worn,have you tried to replace all the consumables in torch,check that all leads are tight.as far as parts go to your local welding store(praxair,midwest air gas, s j smith)not a hardware store,
Apr 02, 2010 | Welding Tools
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
When you plug in welder front coil gets really hot and gun wont feed wire when you push the trigger
you have a short in the inner shiled to the outter shiled, go to the welding shop and buy the inner plastic shield and replace it.
Nov 05, 2009 | Century Portable Plasma Cutter 82021
I'VE GOT HI FREQ BUT NO ARC. SMILEY TOOLS MTC 160. PLASMA, STICK AND DC TIG MACHINE. I DON'T HAVE A MANUAL OR ANY INFO. THANKS
Its probably the torch. Turn off the hf , with the machine triggered Measure the open circuit voltage from the positive o/p socket to the negative with a multimeter set on d.c . The correct no load output voltage for the machine will be shown on the spec plate as Uo = ........and whatever the voltage is. If you get the correct voltage try another torch or try stick welding.
Sep 30, 2009 | Welding Tools
TIG MIG Difference
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Radnor A35HP 350A Water Cooled 25' TIG...
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
MILLER 212735 O-RING PLASMA CUTTER Logo
182 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
