Question about Electric Soldering Gun
Soldering gun maintenance
How to clean the tip after usage?
    New Friend:
  • 160 Answers
I use a damp sponge
Posted on May 19, 2009
  • 2,712 Answers
Start with a clean soldering tip. If it's a new tip, use sandpaper or steel wool so the metal shines. With an old tip, you may need to use a file to remove badly oxidized areas. Once the tip is clean and shiny, press the soldering gun trigger to high and as soon as it's hot, apply a coating of solder to the tip. Use a rag to spread the solder evenly over the tip. The materials to be joined must be clean, dry, and free of grease and oil. Use a wire brush or fine sandpaper to get the surfaces clean and shiny. Make a good mechanical joint. Crimp terminals with a crimping tool or pliers, and twist wires together tightly.
Posted on Aug 27, 2008
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Apr 15, 2017 | Weller Welding Tools
What are the maintenance tips for gun safe owners?
A gun safe need regular and proper maintenance for long life. You may use soft non-abrasive cloth for cleaning. You may not use metal polishes because it will damage your gun safes. Visit Guardwell Safes for buying best gun safes in Dublin
Oct 07, 2016 | Home Security
Soldering gun won't get hot enought to melt solder.
Take off the tip, clean the threads, and replace tightly.
Jul 19, 2016 | Weller Welding Tools
Gun will not heat up tip unlesss it is pressed kind of hard against material? is this the way it is supposed to work...?
This sounds like a "contact" problem where the tip installs in the gun. I would remove the tip and burnish the connections with some very very light sand paper or steel wool (an emery board is a nice 'tool' to add to your tool box). You'll also need to clean the gun connections themselves. Also make sure the connectors are tight, but be careful not to overtighten them or you'll break them. Good connections = good heat transfer. Good Luck.
Jan 25, 2011 | Weller 8200 Soldering Gun
Correct replacement bulb (7194 and 194) burns out immediately when trigger is pulled.
Make sure the copper tip is intact and that the tip nuts have been loosened, then re-tightened to make clean contact of the tip to the gun barrels. The lamp is tied directly across the barrels, and when the tip is open circuited, the output voltage goes up enough to burn out the lamp. Hope this helps!
Jan 08, 2011 | Weller 8200 Soldering Gun
Weller 8200 series soldering gun sometimes fails to heat; tightening screws and/or gently spreading arms often helps. Is there a permanent fix?
There is constant maintenance needed to keep soldering, the key ones are the tip fastening nuts, and the tip itself. The tip eventually needs sanding and immediate retinning, Clean with damp rag during and after each soldering event, and heavily re tin at end of event.
Sep 14, 2010 | Weller Welding Tools
Need to know where I can get tips for a 8200 gun.
Sears Hardware carries Weller and and has tips for the 8200 Weller Soldering Gun, I just swa them yesterday at Sears Hardware.
May 21, 2010 | Weller 8200 Soldering Gun
Black & Decker KX2000K Heatgun Kit 2000w cuts pout after minimal usage is it fuse blown ??
no its not the fuse in the plug but it could be the internal turmal fuse triping out on you,,,if its getting to hot this thurmal fuse will tip out keep intake vents clean and clear when using the hot air gun,,
Aug 27, 2009 | Black & Decker Black and Decker 1500w...
Intermittent heat on Weller D550 although lights stay on. When not working, moving the terminals may get it to start working again. Sometimes, just moving the gun will interrupt the heat. Continuity...
Heat gun tips often get bad electrical connection where the nuts tighten to the tip ends. Remove the tip, clean the ends, re-install the tip, making sure the nuts TIGHTEN onto the tip ends. Your problem is common and always caused by a poor connection at the tip ends/nuts.
Jun 20, 2009 | RTO Weller D550 Soldering Gun
Soldering gun problem
Trying to solder components that haven’t been cleaned properly will result in weak connections. If the tip if the gun is not cleaned correctly, oxidation and deterioration may occur. Periodically running a lightly moistened cloth across the soldering gun during a lengthy work session is the best way to ensure crisp connections. However, you can also purchase special sponges and cleaning pads to care for your soldering gun.
Aug 27, 2008 | Raffael Tools Electric Soldering Gun
Electric Soldering Gun Logo
329 people viewed this question
Top Electric Welding Tools Experts
Bill Boyd
Are you an Electric Welding Tool Expert? Answer questions, earn points and help others
