Question about Milwaukee Tool Weller 300/200 Watts, 120v Industrial Soldering Gun Kit D650PK
Soldering gun Question
What is the differance between a soldering gun to a soldering iron?
    President:
  • 2,712 Answers
Where soldering irons have a heating element that heats a copper or alloy tip; in a soldering gun, the tip is also the heating element. Most soldering guns are hot enough to solder in less than 5 seconds and cool enough to touch in less than a minute. Soldering guns are ideal for the typical home electrical job like connecting speakers or installing automotive accessories. These jobs often have only a few connections to solder so a soldering gun can be a real time saver.
Posted on Aug 27, 2008
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Dennis
Apr 15, 2017 | Weller Welding Tools
Soldering gun melts tips
180 watts is way too much for a soldering iron unless you are repairing copper pipes or soldering 4 gauge wires. You can't just let that stand, it must be used or it will overheat. Harbor freight is were you buy tools that are meant to be used one time. They are junk - I'm not judging you because I don't know what project you have - it is likely a one-time project.
Jan 24, 2014 | Welding Tools
What is the uses of an iron stand ?
Hello, the iron stand is used to keep the soldering iron from tripping over that reason why it so heavy. The coil spring is used to hold the soldering iron and dissipate heat. The with some water will help keep the soldering tip clean. GB...stewbison
Jun 22, 2011 | Trisonic NEW SOLDERING IRON STAND HOLDER +...
Having trouble with solder sticking with metal to metal applications
Soldering is intended for soldering alloys together such as copper, silver, gold....solder does not stick well to steel and aluminum...also, you need to use a flux when soldering...this flux cleans the connections of impurities and allows the solder to stick to the metals to be joined...Judging by the iron that you have...it looks like it is mainly used for very small soldering applications where not too much heat is required...If you want to solder larger items(such as soldering to a metal chassis) then I would recommend using a soldering iron or soldering gun with more wattage
Jan 16, 2011 | Weller Bp860mp Battery Powered Soldering...
I just bought the soldering gun but the instructions on the package aren't very useful how do i use the gun?
A soldering gun is used much the same as a soldering iron for melting solder mainly to connect electronic components to circuit boards. To use it you plug it into the electricity mains and press the trigger. This causes the metal tip to heat up. Allow a minute or so for it to reach full heat and press it to the components you want to solder together. When they heat up press the solder against them. The solder melts and runs on and between them forming a bond. Remove the soldering iron and release the trigger. Once the trigger is released the gun starts to cool down again.
If you've used a soldering iron before you'll probably find the gun more awkward as it cools down every time you release the trigger. It's really only useful for quick jobs where you're not going to need it every few minutes. For other jobs where a lot of soldering is involved a soldering iron is better. The advantage the soldering gun has over the soldering iron is that it heats much faster for quick jobs.
Dec 04, 2010 | Cooper Industries Weller 7200PK 75 Watt...
I am making jewelry with the iron....my tips are dispersing...what is my problem. Should I use a different watt. All that I am doing is soldering over copper foil to broken china.
25 watts is a pretty light iron for the kind of work you are doing, but if it works---. Tips that are just bare copper tend to erode over time (the heat causes the copper to mix with the solder and thus erode). The better tips have iron plating over the copper which protects the copper. Silver solder applied over the bare copper works in much the same way and can be applied with a propane torch. Hope this helps!
Oct 25, 2010 | Weller 25 Watt Soldering Gun Kit
How to disassemble weller soldering iron Magnastat Station - 42W
Hello, if the head element in the barrel of this soldering iron is shot. Recycle it and save the copper and other materials for recycling. Recyclers are pay $3.20/lb for copper, $1.86/lb for brass.
Remove the three screw on the front plate and pull the cord. It's apart. GB...stewbison
Aug 08, 2010 | Weller SP80 Soldering Iron
MY WELLER SOLDERING GUN IS GETTING HOT AND A LITTLE SMOKE COMES OUT NOW AND AGAIN IS THERE ANYONE IN SOUTH AUSTRALIA WHO CAN FIX IT FOR ME AS WELLER SAY THEY DONT DO ANY REPAIRS ON THEM. CHRIS
these are not worth repairing as the main part of a soldering iron is the transformer which is what causes the tip to get so hot, so if yours is giving off smoke and excessive heat probably the transformer is starting to cook itself which means it has to be replaced. I would guess that the transformer will cost you more then a replacement soldering gun on ebay would cost. Hope This Helps Don
Dec 08, 2009 | Weller 8200 Soldering Gun
Weller model 550PK heavy-duty soldering gun is slow to heat up
It depends on what you say is slow, I have used weller soldering guns and desoldering guns for about 30 years. They come up to top heat in about 3min. If it is taking longer than that then there is a problem with the heating unit. You can call weller tech help number, should be on iron base and they can tell you how to test the heat unit.
Mar 24, 2009 | Weller D550PK Professional Soldering Gun...
Tips are corroding & disappearing
That is normal for a soldering gun especially if you are using acid core solder. I do a lot of soldering with rosin core & have to change the tip about every 6-8 months. Just get a couple of new tips. Rick
Mar 06, 2009 | Black & Decker Black Decker Dualtemp...
Milwaukee Tool Weller 300/200 Watts, 120v Industrial Soldering Gun Kit D650PK Logo
383 people viewed this question
Top Milwaukee Tool Welding Tools Experts
Bill Boyd
Are you a Milwaukee Tool Welding Tool Expert? Answer questions, earn points and help others
