Question about CRL Soldering Iron Temperature Control
Soldering Question are there any safety measures to consider while using soldering iron?
    President:
  • 2,712 Answers
# Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will give you a nasty burn. # Take great care to avoid touching the mains flex with the tip of the iron. The iron should have a heatproof flex for extra protection. An ordinary plastic flex will melt immediately if touched by a hot iron and there is a serious risk of burns and electric shock. # Always return the soldering iron to its stand when not in use. Never put it down on your workbench, even for a moment! # Work in a well-ventilated area. The smoke formed as you melt solder is mostly from the flux and quite irritating. Avoid breathing it by keeping you head to the side of, not above, your work.
Posted on Aug 27, 2008
How to make my soldering iron melt solder fast
get a lower melting point solder
get a higher temp tip if so equiped
get a higher wattage iron.
Jul 28, 2014 | Welding Tools
Where can find cheap price china 40w Electric Soldering Iron with 7 pcs welding tool
eBay is the place to get cheap China soldering irons.
I have no idea as to what you're talking about when you ask about a 7 pcs welding tool.
Welding and Soldering are two different things.
Jul 26, 2012 | Weller Welding Tools
What is the uses of an iron stand ?
Hello, the iron stand is used to keep the soldering iron from tripping over that reason why it so heavy. The coil spring is used to hold the soldering iron and dissipate heat. The with some water will help keep the soldering tip clean. GB...stewbison
Jun 22, 2011 | Trisonic NEW SOLDERING IRON STAND HOLDER +...
Having trouble with solder sticking with metal to metal applications
Soldering is intended for soldering alloys together such as copper, silver, gold....solder does not stick well to steel and aluminum...also, you need to use a flux when soldering...this flux cleans the connections of impurities and allows the solder to stick to the metals to be joined...Judging by the iron that you have...it looks like it is mainly used for very small soldering applications where not too much heat is required...If you want to solder larger items(such as soldering to a metal chassis) then I would recommend using a soldering iron or soldering gun with more wattage
Jan 16, 2011 | Weller Bp860mp Battery Powered Soldering...
I just bought the soldering gun but the instructions on the package aren't very useful how do i use the gun?
A soldering gun is used much the same as a soldering iron for melting solder mainly to connect electronic components to circuit boards. To use it you plug it into the electricity mains and press the trigger. This causes the metal tip to heat up. Allow a minute or so for it to reach full heat and press it to the components you want to solder together. When they heat up press the solder against them. The solder melts and runs on and between them forming a bond. Remove the soldering iron and release the trigger. Once the trigger is released the gun starts to cool down again.
If you've used a soldering iron before you'll probably find the gun more awkward as it cools down every time you release the trigger. It's really only useful for quick jobs where you're not going to need it every few minutes. For other jobs where a lot of soldering is involved a soldering iron is better. The advantage the soldering gun has over the soldering iron is that it heats much faster for quick jobs.
Dec 04, 2010 | Cooper Industries Weller 7200PK 75 Watt...
Actually I have 6681, 600w; want to use to regulate 80w soldering iron. Why can I not measure resistance across new switch, before installing? If it is inductive, how can I measure to know it will work? ...
The dimmer isn't a straight resistor, its an R-C timing circuit, and the caps within that circuit are going to mess up any resistance measurement you're trying to make. The R-C circuit is there as a timing mechanism to determinine the duty cycle on/off time of the dimmer. It is because of that, that I recommend you try to not use a light-dimmer for a soldering iron - the dimmers are not resistive rheostats, they're light switches (on and off @ 120-times a second). Depending upon the nature of the soldering iron, that may cause some harmful problems.
Aug 28, 2010 | Leviton Electrical Supplies
Soldering iron doesn't heat up.
The problem is very likely to be a burn-out heating element in your soldering iron: it will now be open-circuit and you can verify this by using a multimeter on the resistance measuring range.
Hope it helps.
Jul 26, 2010 | Weller Marksman Iron 40 Watt SP40L
Iron is not heating up hot enough stained glass soldering iron:
hi friend,
check this out
Consider the wattage of the soldering iron. A good soldering iron will have wattage of 80 to 150. A wattage of lower than 80 is not ideal for stained glass. You need a soldering iron that will melt the solder fast enough for your project. Consider the type of temperature control you want. Some irons will have a temperature control built in the tip. When the temperature drops, it will turn on and when the temperature is reached, it will turn off. Other soldering irons have a built-in rheostat. You control the temperature by turning the dial up or down. A separate rheostat can be purchased to plug your soldiering iron into. Rheostats are highly recommended. This lets you match your temperature to your soldering style and allow you to do decorative effects.
  • Step 2 Consider the heating element. There are two types of elements, ceramic or wire-wrapped. Ceramic core irons maintain heat more efficiently than wound wire heaters. In a ceramic core, the heater core extends into the tip for faster heat transfer. This will keep the tip hot for a longer period so you can work quickly and faster. Ceramic irons maintain their temperature longer and heat up within 30 to 60 seconds.
  • Step 3 Consider the weight of the soldering iron. You want a soldering iron that is lightweight and balanced. You will have less fatigue when using a lightweight soldering iron at long stretches of time. Check to see if it fits your hand comfortably. Check to see if it has a good rubber cushion for your hand.
  • Step 4 Check for the ease of changing tips on your soldering iron. When soldering stained glass, you want to match your tip to the technique you want to use. There are a variety of tips on the market for soldering irons, and you want to be able to change them easily.
  • Step 5 Check the soldering iron to see if it has a heavy-duty cord and a three-prong plug. You want a grounded three-prong plug to prevent the possibility of shock.
  • hope this helps u
    please rate me......................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Weller Welding Tools
    What kind of soldering iron??
    For general soldering of wire and electronic components I use a 60 watt Weller iron.
    What you should use depends very much on what you want to solder.
    Dec 09, 2008 | Welding Tools
    Soldering gun troubleshoot
    # Never touch the tip of the soldering gun. They are very hot and will give you a nasty burn. # Take great care to avoid touching the mains flex with the tip of the gun. The gun should have a heatproof flex for extra protection. An ordinary plastic flex will melt immediately if touched by a hot gun and there is a serious risk of burns and electric shock. # Always return the soldering gun to its stand when not in use. Never put it down on your workbench, even for a moment! # Work in a well-ventilated area. The smoke formed as you melt solder is mostly from the flux and quite irritating. Avoid breathing it by keeping you head to the side of, not above, your work.
    Aug 27, 2008 | Weller 8200 Soldering Gun
    CRL Soldering Iron Temperature Control Logo
    158 people viewed this question
    Top CRL Welding Tools Experts
    Bill Boyd
    Are you a CRL Welding Tool Expert? Answer questions, earn points and help others
