Question about Cooper Industries Weller Field Soldering Iron, Controlled Output
Soldering iron support
What is an anti static protection?
    President:
  • 2,712 Answers
Anti-Static Protection: If you're interested in soldering a lot of static-sensitive parts (e.g. CMOS chips or MOSFET transistors), more advanced and expensive soldering iron stations use static-dissipative materials in their construction to ensure that static does not build up on the iron itself. You may see these listed as "ESD safe" (electrostatic discharge proof). The cheapest irons won't necessarily be ESD-safe but never the less will still probably perform perfectly well in most hobby or educational applications if you take the usual anti-static precautions when handling the components. The tip would need to be well earthed (grounded) in these circumstances.
Posted on Aug 27, 2008
I cant get the clock on my kitchenaid microwave to stay on
Hello Jimmy Hester,
This could be a GREAT TIME to consider
calling in a PROFESSIONAL...
They walk in... pull out the wall plug... pull
out the PC board... Poke the soldering iron at a
BAD (cold solder) joint... BINGO ... all is well.
Mishandling a CIRCUIT BOARD could change
a minor issue to a MAJOR FAILURE... EASY.
There are a couple of REALLY great reasons these
appliances say ...
"NO USER SERVICEABLE PARTS INSIDE"
- Primary: novices & amateurs (where EVERYBODY
real actually started) need to be trained to wear
STATIC Protection... $6 (for a good one, see below).
A simple wrist strap. Electro-STATIC spark you might
not even feel is enough to DESTROY any semiconductor
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Could also be a simple PC Board "re-seat"...
if it is done with the POWER ON... the oven gets
ruined.
You really ought consider adding in the
MAKE & MODEL.. You will be rewarded with
much better than scary stories...
If you do manage to get a wrist band... actually
remove POWER... & get that control board (PC)
out... Look at the solder side... Check for soot or
obvious cracks.
Use a really bright light and a jewelers loop.
We can guide you with a solder sucker... good iron,
soldering wick... goggles... burn proof flooring, clothes
and furniture...
But as you start adding up all the costs... and the remote
chance of success...
Would it NOT BE EASIER... to look up a 5 STAR repair
shop... (not my normal recommendation)
I'm just saying... Soldering is not as EASY as it looks.
Carnac the Magnificent
IRON
Weller W60P3 60Watts 120V Controlled Output Soldering Iron With 3 Wire...
Sucker (braided copper wick)
https://www.amazon.com/Puraid-CP-2015-Desoldering-Soldering-Accessory/dp/B01MRGSLIS/ref=sr_1_4_s_it?s=hpc&ie=UTF8&qid=1513915911&sr=1-4&keywords=desoldering+tools
Vacuum sucker
Amazon com Ingdy TM 1pc Solder Sucker Desoldering Pump Tool Removal Vacuum...
Dec 19, 2017 | KitchenAid Microwave Ovens
Overhead car kenwood dvd player is constantly show disc error.. What is causing this error?
Possible error is the data is not read by the optical head.
So clen the lens eye to check if the faultt changes. If not the optical head assembly must be changed.
Use proper method to change the new Head, remove the static short of solder to prevent static damage to the head if touched or solderred by leaky soldering irons.
Use an anti static iron to do the job.
Sep 20, 2010 | Car Audio & Video
How do i make my ps3 reconize the new laser?
u need to remove the anti static solder blob on the laser chip, just gentle heat from a solder iron for a couple of seconds is all thats needed, the laser wont work until this has been done!!,
Mar 11, 2010 | Video Game Consoles & Games
Bad power supply/capacitors Xerox M15i WorkCentre. how do I order parts, and how do I repair/replace
Hi
I have to make some assumptions here. Since you know that there are bad capacitors on the power supply board then you'll need to get replacements. When you go to order these make sure you order the exact part i.e. .5ufd, 100vDC, 70temp and 57hz frequency. This is a poor example but ordering the exact replacement part is very important. There are hundreds of places to get the caps online. Now to replacing these. If you have enough electronics knowledge to determine if these caps are bad then I have to assume you can replace these fairly easily. This will only require simple tools i.e. anti-static 30w watt soldering iron, anti-static desolder device, anti-static wrist strap with known good ground. Appropriate solder. Good luck
Mar 10, 2010 | Xerox WorkCentre M15i Laser Printer
Ps 2 slin not spinning just replace old laser by new one
Sounds like either you got a bad laser, or if the anti-static solder point on the left side of the new laser was not removed with a soldering iron, then the laser will not work. Simply heat it with an iron and maybe some solder wick and you should be good to go.
Nov 27, 2009 | Sony PlayStation 2 Slimline Console
Ok so my laser went out in my xbox 360 and i bought a new one and i put it in and now it just wont turn on.... what happened?
there is an anti-static point that needs to be desoldered for the new laser to work. Check the link below and then select what drive laser you are trying to replace...
https://xbox-experts.com/e/tutorial.php?n=laserreplace
Mar 06, 2009 | Microsoft Xbox 360 Console
Does installing a KEM-400AAA require soldering?
No, there is no soldering involved with replacing a kem-400aaa. You can do this with just a screw driver.
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Soldering Question
# Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will give you a nasty burn. # Take great care to avoid touching the mains flex with the tip of the iron. The iron should have a heatproof flex for extra protection. An ordinary plastic flex will melt immediately if touched by a hot iron and there is a serious risk of burns and electric shock. # Always return the soldering iron to its stand when not in use. Never put it down on your workbench, even for a moment! # Work in a well-ventilated area. The smoke formed as you melt solder is mostly from the flux and quite irritating. Avoid breathing it by keeping you head to the side of, not above, your work.
Aug 27, 2008 | CRL Soldering Iron Temperature Control
PSP Anti-static solder point removal
it is helpful if you get some desoldering braid from your local diy shop. you just heat the braid on the solder joint and .... zip... the solder runs up the braid.
hope this helps
danolsta
Dec 11, 2007 | Sony PlayStation Portable (PSP) Console
Cooper Industries Weller Field Soldering Iron, Controlled Output Logo
194 people viewed this question
Top Cooper Welding Tools Experts
Bill Boyd
Are you a Cooper Welding Tool Expert? Answer questions, earn points and help others
