Question about Bosch 18V Cordless Planer 53518
Nail Gun cost
How much does a nail gun usually costs?
    President:
  • 2,712 Answers
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Posted on Aug 27, 2008
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Hitachi nail gun,piston/nail push rod wont retract after pushing nail (stays protruding out of gun so the remaining nails stay underneath it
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
Oct 25, 2010 | Hitachi Tools & Hardware - Others
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
May 31, 2009 | Stanley Bostitch F21PL Nailer
Staple,nail gun, how do i install the nail properly
SHOULD BE A SPRING LOADED TAB LOCATED USUALLY AT THE REAR OF THE GUN. PRESS IN THEN DOWN AND SOULD POP OUT SO YOU CAN LOAD.
PLEASE RATE
THANKS
Nov 13, 2008 | Tools & Hardware - Others
I have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
Sep 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Nail Gun cost
Sep 01, 2008 | Makita Brad Nailer Finish Nailer...
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Nail Guns costs
Aug 27, 2008 | Arrow ET200 Electric Brad Nail Gun
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Bosch 18V Cordless Planer 53518 Logo
220 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
