Question about Rotary Viking High Speed Tools: Sanders - 20,000 RPM. 90 psi. 4 cfm. Air In
Air Sander Guide
Are there any safety guide lines I should follow?
  • 2,418 Answers
Wear safety glasses or a face shield. May even wear a dust mask depending on material your working on. Gloves may help also. can't think of anything else, work slow, be proud of your work, even if you mess up a little, remember you did it your self.
Posted on Jul 01, 2009
    President:
  • 2,712 Answers
# Ensure that sanding belts are not too tight or too loose. Never operate a sanding disk if the paper is loose. # Use the correct grade of abrasive material for the job. # Ensure that the distance between a circular sander and the edge of the table is not greater than 1/4 inch. # Do not push materials against sanders with excessive force. # Sand only on the downstroke side of a disk sander. # Do not hold small pieces by hand. Use a jig for pieces that are difficult to hold securely
Posted on Aug 27, 2008
How to assemble an ingersoll rand sander 315
Gear timming in line sander
The above link may help as the unit is similar to the Central Pneumatic Straight Line Sander
Mar 02, 2015 | Ingersoll Rand Ingersoll-Rand IR 315 Heavy...
I have a power devil belt sander, but every time i turn it on for use the belt works its way off... i bought this sander second hand at a boot sale so im thinking is there supposed to be an outside guide...
no there is not anything missing, you need to adjust the belt by turning the black plastic adjuster knob which guides the belt to the left. I have found that whilst using the sander you sometime need to adjust it further. If you adjust it too much the belt will hit and grind the plastic casing of the sander.
Also make sure you are using the correct size belt as it should be size 75X533 which you can buy from Toolstation for £2.78 a pack of 5.
Sep 03, 2011 | Electric Power Belt Sander, 3" X 21" 700...
Air and dust no longer blow into dust collection bag. I suspect that there is a clog somewhere.
are you putting holes in the papper with the guide? there has to be holes in the paper for the dust collection to work
Oct 15, 2010 | Dewalt DW411 quarter - sheet palm grip...
My belt sander is eating away to much on the left side and it is also leaving cut lines on the floor.. does anyone have a solution or a guide to how to fix this problem? my floor sander is a "Clarke...
I would first look at the discs for uneven wear but if you want and I would recommend going to "Clarkeamericansander.com" they hae service and support and technical services who can better serve you. they also have tool free numbers listed for assistance. where I work I have called them are they are really there to help. Good Luck
Sep 23, 2010 | Clarke Floor Sander Floor Sander Orbital...
Friend took my 900420 nailer apart to clean it and when he got done, had a small spring about 3/16" x 1" left over. Does anyone have a clue where it might go?
Thin spring?
Goes in-between the Follower Guide and Button.
There are several Coil springs used in a Paslode 900420 framing nailer.
1.In-between the Upper Probe and the Lower Probe.
(Safety device you depress so the gun will shoot)
2.Trigger
3.Lockout Bar
4.Follower Guide and Button
(There is a flat spring also. Goes in-between the Probe Stop and Probe Release)
Here let me show you,
http://www.paslode.com/uploadedFiles/Cordless_Framing_Nailer_Parts_Diagram_Schematics.pdf
Oct 17, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Sander stalling
Try to increase the psi to 125,if possible.also clean the air tool out with wd 40 and or auto trans.fluid.Try this and put it in the end of gun where the air goes in at.
Aug 29, 2009 | Chicago Pneumatic CP864 Dual Action Air...
WHAT OIL IS RECOMENDED FOR IR315 STRAIGHT LINE AIR SANDER
I just use my regular air tool oil on mine, have several of these IR longboards. Rick
Mar 20, 2009 | Ingersoll Rand HD Air Twin Piston...
Safety guidelines
Aug 27, 2008 | Coleman Powermate 18 Volt Cordless Sander,...
Rotary Viking High Speed Tools:  Sanders - 20,000 RPM. 90 psi. 4 cfm. Air In Logo
466 people viewed this question
Top Rotary Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Rotary Air Tool and Compressor Expert? Answer questions, earn points and help others
