Question about Taylor Pneumatic: DA Sanders: 10000RPM. 90PSI. .5HP Motor. Pad Dia: 6". Air
Air Sander tips
How to use my Air Sander efficiently?
    President:
  • 2,712 Answers
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Posted on Aug 27, 2008
How to assemble an ingersoll rand sander 315
Gear timming in line sander
The above link may help as the unit is similar to the Central Pneumatic Straight Line Sander
Mar 02, 2015 | Ingersoll Rand Ingersoll-Rand IR 315 Heavy...
SANDER RPM IS LOW , EVEN AFTER MAX AIR SUPPLY
Turn dial on side,or on bottom of sander should change rpm.
Sep 19, 2012 | Ingersoll Rand 313A IR-313A 7"Dia 5000RPM...
I want oil for the 7" air angle sander polisher by Neiko
http://www0.shopping.com/xFS?KW=sander+machine+oil&CLT=SCH
May 15, 2010 | Sander 7" AIR ANGLE SANDER POLISHER ...
Dynabrade sander doesn't spin
check the exhaust muffler. or just take it off and see what happens.
there is usually an inlet air adjustment on the palm sander itself one of these will correct your sander.
if not, and your air supply is good. put some air oil in it or even a light weight oil will work.
if none of this is the correct action to get it going. its probably toast!
Mar 03, 2010 | Dynabrade 56818 5" Supreme Vacuum Orbital...
Sander stalling
Try to increase the psi to 125,if possible.also clean the air tool out with wd 40 and or auto trans.fluid.Try this and put it in the end of gun where the air goes in at.
Aug 29, 2009 | Chicago Pneumatic CP864 Dual Action Air...
WHAT TYPE OF AIR SANDER WOULD YOU RECOMEND TO SAND MACHINERY WITH HEAVY COAT OF ENAMEL PAINT
A random orbit air sander with a fairly course grit paper would probably do the job well. At least 60 grit or even down to 40 grit should remove almost anything.
Jun 03, 2009 | Northern Industrial Tools Horizontal Air...
Belt sander 3x24 Porter Cable
Try some "Simple Green" concentrate cleaner, or the "Simple Green" barbecue cleaner in a spray can to clean the roller. Should not use a dremel as you probably know now because of damage.
Another good idea is to blow out the tool after each use with compressed air. An air compressor is a great tool for a lot of things!
May 30, 2009 | Porter Cable Cable Tools 3" X 24" Belt...
DA SANDER RPMS SLOWED
get some air tool oil and oil it lol, if that will not speed it back up you may have to take it apart and clean it but the oil should do the trick. Do NOT use wd40, etc. use air tool oil
May 23, 2009 | Chicago Pneumatic 864 6" Heavy Duty Dual...
Sander stops
There can be a few problems. First is your air supply the right pressure and volume for the sander. Check that at the quick connector to the sander itself. Second, if it is cold and moisture is high, ice can get into the sander which will slow it way down. Third, and probably most likely cause, is the sander well oiled and the parts inside clean. Fourth, mechanical issues: the drive motor may be well worn out inside, the bearing that the main shaft for the sander may be worn out & so forth. Hope this helps you, Rick
Apr 28, 2009 | Air Tools & Compressors
Taylor Pneumatic: DA Sanders: 10000RPM. 90PSI. .5HP Motor. Pad Dia: 6". Air Logo
262 people viewed this question
Top Taylor Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Taylor Air Tool and Compressor Expert? Answer questions, earn points and help others
