Question about Taylor Pneumatic: Orbital Sanders: 8000RPM. 90PSI. Pad Dia: 3-2/3" x 9". Ai
Air Sander Question
What do I need speed control for?
    President:
  • 2,712 Answers
When you are finishing the surface of wood, it's vital to maintain control. Work too fast or too slow and you risk ruining your hard work with unsightly scratches
Posted on Aug 27, 2008
Cant figure out how to install the sanding disc's
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Jul 23, 2009 | Dewalt d26451k 5" random orbit sander kit...
Bosch ROS not powering on
Checked the net for answers and got a couple of maybe's. 1.) Brushes, 2.) variable speed control, which some were direct wiring.
I tried the brushes firs and that has solved the problem for now. I guess the brushes stuck or somehow lost contact.
I got a parts diagram and found the brushes (will be covered with dust). Took the springs out and stretched them a little, replaced and the sander turned on. You will need to remove the top cover to do this. Verdit is still out as to long term performance. Not a great start.
My particular sander was lightly used (second project) and it has not been abused.
Jul 11, 2009 | Bosch 1295DVS 5" Palm Variable Speed...
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
DA SANDER RPMS SLOWED
get some air tool oil and oil it lol, if that will not speed it back up you may have to take it apart and clean it but the oil should do the trick. Do NOT use wd40, etc. use air tool oil
May 23, 2009 | Chicago Pneumatic 864 6" Heavy Duty Dual...
Sander stops
There can be a few problems. First is your air supply the right pressure and volume for the sander. Check that at the quick connector to the sander itself. Second, if it is cold and moisture is high, ice can get into the sander which will slow it way down. Third, and probably most likely cause, is the sander well oiled and the parts inside clean. Fourth, mechanical issues: the drive motor may be well worn out inside, the bearing that the main shaft for the sander may be worn out & so forth. Hope this helps you, Rick
Apr 28, 2009 | Air Tools & Compressors
As soon as i apply my sander to the surface it stops sanding
hi a major problem with pneumatic tools is that nobody ever seems to oil them! try droping tool oil or a light machine oil down the air inlet and leave over night and then run the tool on full ,if this doesnt work then strip the tool and clean and make sure that the blade sealing surfaces are good
hope this helps ian
Mar 21, 2009 | Dynabrade 57810 Dynabug Orbital Air Sander...
Need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Air Sander Guide
# Ensure that sanding belts are not too tight or too loose. Never operate a sanding disk if the paper is loose. # Use the correct grade of abrasive material for the job. # Ensure that the distance between a circular sander and the edge of the table is not greater than 1/4 inch. # Do not push materials against sanders with excessive force. # Sand only on the downstroke side of a disk sander. # Do not hold small pieces by hand. Use a jig for pieces that are difficult to hold securely
Aug 27, 2008 | Rotary Viking High Speed Tools: Sanders -...
Speed Control Question
Aug 27, 2008 | Coleman Powermate 024 0091CT High Speed...
Taylor Pneumatic: Orbital Sanders: 8000RPM. 90PSI. Pad Dia: 3-2/3" x 9". Ai Logo
170 people viewed this question
Top Taylor Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Taylor Air Tool and Compressor Expert? Answer questions, earn points and help others
