You can add different sanding discs to an orbital air sander to ensure that it is properly set up for a huge variety of different jobs. From heavy duty sanding paper for tough jobs through to buffing cloths in order to get a final polished finish at the end of the job. With most orbital air sanders, changing the disc takes just a few seconds, allowing you to get a variety of jobs done a lot quicker.
Woodworking and metalworking are a long and difficult process. We understand how important adding beautifications to your work can be. Air sanders might be the right tool for this kind of job. More details about the air sanders go to the link The Ultimate Gedu Professional Air Sander Review
check the exhaust muffler. or just take it off and see what happens.
there is usually an inlet air adjustment on the palm sander itself one of these will correct your sander.
if not, and your air supply is good. put some air oil in it or even a light weight oil will work.
if none of this is the correct action to get it going. its probably toast!
Try to increase the psi to 125,if possible.also clean the air tool out with wd 40 and or auto trans.fluid.Try this and put it in the end of gun where the air goes in at.
A random orbit air sander with a fairly course grit paper would probably do the job well. At least 60 grit or even down to 40 grit should remove almost anything.
Normally when the air will not drive the tool, it is because 1- the tool is rusted up inside, 2- there is no lubrication of the moving parts - which can be remedied by putting something like WD40 in the inlet with the air switch open, 3- the drive parts are broken or worn out, 4- not enough air volume/pressure to run the sander.
You probably need to spray some lube as above & see if that will get it to work. Also turn the sander part by hand. Rick
# Ensure that sanding belts are not too tight or too loose. Never operate a sanding disk if the paper is loose.
# Use the correct grade of abrasive material for the job.
# Ensure that the distance between a circular sander and the edge of the table is not greater than 1/4 inch.
# Do not push materials against sanders with excessive force.
# Sand only on the downstroke side of a disk sander.
# Do not hold small pieces by hand. Use a jig for pieces that are difficult to hold securely
* Proper match between air compressor and tool ratings.
* Correct fittings that match the tool and air hose.
* Well-maintained air compressor and air hose.
* Correct air pressure adjustment for the tool being used.
Portable air compressors give flexibility to the job both inside and outside the working environment. They're powered by electric, gasoline or diesel engine. A larger portable air compressor often has its own carrying trailer with wheels and handles. You buy a compressor based on its horsepower, pounds per square inch (PSI) and cubic feet per minute (CFM). Choose a portable air compressor to make work quicker and easier. Figure the amount of power you need based on the type of job and air tools used. Know the cubic feet per minute (CFM), such as 5 CFM for small household tools and 10 CFM or more for wrenches or sanders. All air tools have these ratings. Select a gas- or electric-powered engine. Gas gives a higher reliability for frequent use and portability, but consider electric for enclosed areas for its lack of fumes. Pick an air tank based on amount of use time and tools. Large tanks are best for longer use with sanders or grinders and smaller tanks for less time, like wrenches and air hammers. Consider the pump type you need: belt for heavy use or direct-drive for light home use. The quieter belt-drive pump needs periodic oil changes. Buy an inexpensive, small electric portable air compressor for small jobs. These typically operate from a 12-volt power outlet and inflate a 14-inch tire in a few minutes. Get a 150 PSI, 120 volt motor pancake-type air compressor for home use. These light-use models typically carry two air couplers, allowing hook up of two air tools and adequate 25 feet or more air hose. Obtain a larger PSI portable air compressor for bigger jobs, like nailing, with longer continuous use capabilities.
