Question about Ingersoll Rand 231C Ks 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Driver Set
Air Drill Support
What uses are there for an air drill
    President:
  • 2,712 Answers
Drill operated by compressed air, used in mining and tunnelling, for drilling shot holes (for explosives), and in road repairs for breaking up pavements. It contains an air-operated piston that delivers hammer blows to the drill bit many times a second.
Posted on Aug 27, 2008
What do you mean by drill less dentistry?
A drill-less dentistry consists of preparing the decayed surface of teeth for bonding or filling purposes with an air stream of tiny particles. In conventional dental filling decayed surface is prepared by drilling the tooth with tiny drills which produces discomfort and pain among patients apart from sound. Recently I got treated from a Dental care center in Scarborough and they adopted drill-less dentistry technology for my dental filling and it was found quite comfortable.
Sep 23, 2013 | Drills
Tip
How to use an Electric Drill
  • First You need to choose which kind of electric drill you are going to use - the cord or cordless. The one who has a cord attached might limit you because it need to have an outlet.although, it powerful then the cordless drill. On the other hand, the cordless drill can be use anywhere without needing an outlet.
  • Choose the wright drill according to your job. For an heavy-duty project purchase a more powerful drill but remember that it run slower and most of them have a cord attached to them. If you have lightweight jobs so you can use a cordless drill.
  • The safest way to use a drill is to make sure that the materials to are drilling are straight ahead of you or down below you. in additional, in case that the materials you are drilling is hard or thick one, in first use a hole punch to start the hole before the drill.
  • When you starting the job, push the drill slightly. start out slowly, and as the hole progresses, increase the speed slightly.
on Aug 27, 2008 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Chuck on ingersoll rand air drill doesn't turn even without air pressure
pull it apart and check bearings and fibre blades check that they are not cracked or jammed from dried lubricant.
Oct 02, 2011 | Ingersoll Rand Ingersoll-Rand 1/2" Heavy...
My 1/2 inch drive air drill stopped working i have model number 19912.motor is running but chack is not turning
MOst likely the planetary gears in the head og the drill. There is a small pinion gear which drives the larger gear to make the chuck turn.
Jan 10, 2010 | Craftsman Nailer Kit, Palm Air Driver
Aircat 4412ACR drill
Most likely will not. all over the internet are bad customer service ratings and warrenty issues. The tool is really not that expensive to be disposable. Sorry.
Jul 01, 2009 | Aircat 1/2'' Air Power Reversible Drill...
How to change an air drill chuck
If the screw will not loosen use an impact drver with the proper size allen bit on it.
example:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_36882_36882
Apr 01, 2009 | Air Tools & Compressors
Drill Question
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools
Aug 27, 2008 | Ingersoll Rand 231C Ks 1/2" Super Duty Air...
Air drill tips
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Air Drill Problems
Squeeze 4-5 drops of pneumatic tool oil into the air fitting daily. If you use the tool all day, repeat the process half-way through the day. If you don't use the tool very often, just oil it when the tool is used.
Ingersoll Rand 231C Ks 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Driver Set Logo
230 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
