Question about Ingersoll Rand 271 Super Duty 1 Inch Pnuematic Impact Wrench
Air Wrench Question
How does it work?
My impact when the press the trigger the air come from above the trigger and the wrench dose not work
Posted on Dec 26, 2008
  • abennett5081 Dec 26, 2008
    1/2 air wrench does not turn when pressing the trigger made by huasfield manfactor
    President:
  • 2,712 Answers
An impact wrench works in the manner suggested by the name of the tool: through the principle of impact. In order to understand how an electrical or air-powered impact wrench works, it helps to know first how a manually powered impact wrench operates. A manually powered impact wrench looks like a fat screwdriver; on the end where the screwdriver blade normally goes, you can snap on screwdriver bits or sockets.
Posted on Aug 27, 2008
Will 3.8cfm @90lb pressure air compressure 10 gallon 125psi work with impact wrench at average air consumption 8cfm
Air tools demand volumes of air; a 10 gallon is good for something like a finish nailer, or staple gun, or even a nail gun.
It will run the impact wrench, just not for very long, like 10 to 12 seconds if you're lucky.
Most compressors tell you what types of tools they are made for.
And impact gun is best matched with a 21 - 26 gallon compressor.
Nov 03, 2015 | Air Tools & Compressors
Repair wrench
This should help identify Parts for your zinger doll Rand #261 Air Impact Wrench...
Look here:
http://www.atecsarl.com/wp-content/uploads/2013/08/271.pdf
Apr 17, 2014 | Ingersoll Rand 3/4" Drive Super Duty Air...
Farmhand fht586
Robert,
From your description, it sounds as though the air wrench may be dry. What that means is that you need to oil the wrench through the air chuck attachment. Turn the wrench over and add several drops of air tool oil which you can get at most tool stores or home improvement centers. Then re-attach the air supply and try the wrench again. If the wrench has not been oiled for a long time, it's possible that the rotor or vanes are seized, in which case the tool will need to be dismantled and the vanes and/or rotor and bearing might need replacement. If that's the case, you'd be better off replacing the wrench. Make sure you have enough air pressure to run the tool. Air tools should be oiled frequently, expecially if they are used with un-dried compressed air or if they see heavy use.
One other thing - make sure the reversing switch is not in "mid" position and is either in forward or reverse.
Good luck sir
Oct 29, 2013 | Computers & Internet
Impact wrench will not reverse
Hi sureputtcup...
Try this solution:
Spray some WD40 into the air intake of the impact wrench and then hook up your air hose to the wrench...run it a few seconds in forward....then after running in forwards for a few times, disconnect the wrench again, and again spray a small amount of WD40 into the air intake of the wrench...again run in forward...after running in forward again, then try to reverse the rotation...turn to reverse..
This will sometimes free up the vanes and sticky parts and allow the wrench to work properly.
If this does not work then you will need to disassemble the wrench and clean and oil and reassemble.
Please take time to rate me 4 thumbs up
Sep 03, 2011 | Garden
Impact wrench is not working at all.the air is coming out of the hole at the bottom of wrench next to where the air hose is hooked up.
fill down the air pipe wit penatrating oil hold trigger and keep movin forward and reverse wen in frees up fill wit airtool oil
Aug 10, 2010 | Craftsman 1/2" Impact Wrench
1" Cp797 Air Impact Wrench Standard: it works for a while and then just blows air , but...
THE TOOL NEEDS TO BE DISASSEMBLED AND CHECKED FOR WATER IN THE AIR MOTOR, ALSO CHECK THE COMPRESSOR FOR WATER.
FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC
Part Listing Order Page
May 18, 2010 | Chicago Pneumatic 1" Cp797 Air Impact...
Is the torque on on air wrench sufficient enough
which impeller shaft? is it XL125? If you mean drive shaft the air wrench will work
Apr 08, 2010 | 1986 Honda XL 125 R
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
Wrench Support
An impact wrench also requires a few special accessories. An air-powered impact wrench runs off of an air compressor with a tank – the air compressor should have at least a 10 gallon tank and be able to generate at least 3hp. Also, an impact wrench requires special sockets that are designed to withstand the high torque applied by the wrench.
Aug 27, 2008 | Impact 3/4" Dr. Heavy - Duty Air Wrench
Wrench Problem
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Ingersoll Rand 236 1/2" Air Impact Wrench
Ingersoll Rand 271 Super Duty 1 Inch Pnuematic Impact Wrench Logo
654 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
