Question about Ingersoll Rand 1/2" Dr. Super Duty Impact Wrench
Wrench Question what is the difference between electirc and air powerd tool?
    President:
  • 2,712 Answers
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools
Posted on Aug 27, 2008
Farmhand fht586
Robert,
From your description, it sounds as though the air wrench may be dry. What that means is that you need to oil the wrench through the air chuck attachment. Turn the wrench over and add several drops of air tool oil which you can get at most tool stores or home improvement centers. Then re-attach the air supply and try the wrench again. If the wrench has not been oiled for a long time, it's possible that the rotor or vanes are seized, in which case the tool will need to be dismantled and the vanes and/or rotor and bearing might need replacement. If that's the case, you'd be better off replacing the wrench. Make sure you have enough air pressure to run the tool. Air tools should be oiled frequently, expecially if they are used with un-dried compressed air or if they see heavy use.
One other thing - make sure the reversing switch is not in "mid" position and is either in forward or reverse.
Good luck sir
Oct 29, 2013 | Computers & Internet
My electirc impact does not have power under pressure
check the specs and make sure your not pushing it harder than it was built for.
replace the brushes
Jan 28, 2012 | Craftsman 1/2" Impact Wrench
Is the torque on on air wrench sufficient enough
which impeller shaft? is it XL125? If you mean drive shaft the air wrench will work
Apr 08, 2010 | 1986 Honda XL 125 R
Where do i get a replacement trigger, mine is
If your local Sears store can't help you, try looking to see if you have a Snap-On, Corn-well, or Matco tool distributor in your area. Many air tools are manufactured by companies who make tools for different distributors. I work in a shop, and have found that many of the tool trucks have parts that'll work on other brands of tools besides their own.
Dec 13, 2009 | Craftsman 1/2" Impact Wrench
Air sander problem
Aug 27, 2008 | Taylor Pneumatic: Straight Line Sanders:...
Drill Question
Aug 27, 2008 | Ingersoll Rand 231C Ks 1/2" Super Duty Air...
Ratchet Question
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools.
Aug 27, 2008 | Chicago Skates Chicago Pneumatic 7830 3/8"...
Hammer problem
Aug 27, 2008 | Northern Industrial Tools Air Hammer 2...
Wrench Problem
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Ingersoll Rand 236 1/2" Air Impact Wrench
Ingersoll Rand 1/2" Dr. Super Duty Impact Wrench Logo
146 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
