Question about Ingersoll Rand Air Hammer - 2 9/32in. Stroke, 3000 BPM, 3 CFM, Model# 121Q
Air hammer problem
How to use my air tool most efficiently?
  • 3 Answers
Well for starters always oil before you use it and while using it you must have constant pressure on it or you will wear down the anvil alot faster and the best air pressure is 90 psi (6.2 bar) air consumption is 7 cfm
Posted on May 29, 2009
    President:
  • 2,712 Answers
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Posted on Aug 27, 2008
No power and just blows air
The problem stated could be in one of two places.
1st the hammer mechanism, symptom when trying to loosen or tighten a nut the tool locks up. Disassemble and and check components for wear or broken parts..
2nd under a no load condition, depressing the trigger and only air blows through the exhaust could be a combination of hammer and motor. Also must inspect the anvil bushing (item #19) located in the hammer case, they have a tendency to slide out of place and binding the mechanism as a whole, then check air motor for scarred a
endplate (item # 12) cylinder (item# 9, damaged vanes (item# 11)
Follow this link to the parts list. http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
Oct 23, 2013 | Ingersoll Rand 1/2" Air Impact Wrench Gun
Ingerroll rand 2132g how do I oil my air impact wrench?
Most I.R. impacts require grease in the hammer mechanism (clutch) and oil in the air motor.
To lubricate the air motor simply add oil through the air inlet about 3 to 6 drops at every use.
To lubricate the hammer (clutch) mechanism you will need a grease gun with a needle, the grease fitting (item# 17) is located on the hammer case assembly (item# 15) 2 or 3 small squirts will sufficiently lube the hammer (clutch) mechanism.
With heavy use grease the tool once a month, with light use 2 to 3 times a year.
Follow this link for the parts list, also indicates the grease needed:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80164726_ed4.pdf
Aug 04, 2013 | Impact Husky® 1/2" Wrench
Runs but when you try running on a nut it just blows air. should the plates and drum be greased when rebuilt?
The air motor on the 285B needs to be oiled, the hammer section needs to be greased. The symptom described could be in the hammer mechanism, 285B's have 2 different side plates (item# 41) that sit atop the hammer mechanism, tools made from 2005 to 2007 use the old style side plate (item# 41) that has a small lip that need to sit looking toward the hammer case bushing (item# 44) when installed with the small lip facing in to the hammer will cause it to lock, tools made from 2008 to the present have a side plate that is flat on both sides and can be installed in either position. also check the hammer and anvil for cracks and pitting.
Follow this link to view the parts list.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80162944.pdf
Jun 01, 2011 | Ingersoll Rand Ingersoll - Rand 285B - 6...
My cp-714 air hammer runs slowly when the tigger is not depressed, what causes this?
More then likely you have a bad oring on the valve. This tool has lousy valve. If you need help or patrs contact KCTool 715 445 7700. Good people.
Oct 25, 2010 | Chicago Pneumatic CP714 Heavy Duty Air Zip...
Air Sander tips
Aug 27, 2008 | Taylor Pneumatic: DA Sanders: 10000RPM....
Air hammer Question
Air hammers are ideal for some specific jobs of craftsmen. Since they do not require your hand to hold the nail stationary, they are safer than conventional hammers. In addition, since air hammers do not involve swinging, they are perfect for projects that require a great deal of nailing, such as installing drywall. This will help you save energy and complete your task more efficiently
Aug 27, 2008 | Standard Duty Air Hammer
Air hammer tips
Always keep in mind that air hammers are extremely powerful tools. Thus, particular safety precautions should be taken when using them. Be certain to wear safety equipment such as safety glasses and earplugs. Also, when changing the air hammer's bits, always be sure to unplug the air hammer first. Finally when using an air hammer, always be aware of the position of the tool and work piece. The tremendous force that the air hammer exerts can cause the tool or work piece to jump powerfully. This movement could easily cause injury to the operator.
Aug 27, 2008 | Ingersoll Rand Air Hammer 2 9/32" Stroke,...
Hammer problem
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools
Aug 27, 2008 | Northern Industrial Tools Air Hammer 2...
How to use a Ratchet
Aug 27, 2008 | Campbell Hausfeld Professional 1/4"...
Air drill tips
Aug 27, 2008 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Ingersoll Rand Air Hammer - 2 9/32in. Stroke, 3000 BPM, 3 CFM, Model# 121Q Logo
355 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
