Question about Campbell Hausfeld 1/2" Ratchet
Ratchet troubleshoot how to keep the feed system in good shape?
  • Anonymous Oct 08, 2008
    I AM IN MANUFACTURING AND I CAN NOT FIND A 1/4" AIR RATCHET THAT WILL STAND UP TO HEAVY DAILY USE WITHOUT THE RATCHET HEAD WEARING OUT AND LOCKING UP. WE OIL THE TOOL DAILY(IF NOT HOURLY) BUT EVEN THE "HEAVY DUTY" RATCHETS WILL NOT LAST LONGER THAN A FEW WEEKS.
    President:
  • 2,712 Answers
The feed system should be smooth all the way forward. For cleaning, wipe off the magazine or blow it out with air rather than using an oily lubricant. The lubricant actually attracts dirt and debris.
Posted on Aug 27, 2008
What are the things to be considered while purchasing a Wrench Ratchet Set?
The point that needed to be first noticed is its right shape and size. Ratchet mechanism and different factors are also needed to be considered while choosing a particular wrench.
Some of the important factors are:
a. Right kind of alloy
b. Deep sockets
c, Look for a good warranty
d. Material used
Backyard Tool Shed will provide you complete guidance on choosing a best ratcheting wrench set.
Nov 28, 2017 | Cars & Trucks
How do I release belt tensioner 2007 Toyota rav 4 4cyl
I just changed the serpentine belt on a 2003 Toyota RAV4. The 3/4 protrusion is the correct place to relieve the tension. A half inch drive socket ratchet and cheater bar is necessary to relieve the tesion on the belt. It is a pain in the *&^% to do. Also if the belt is not stretched you have to turn the alternater pulley with a #10 socket and ratchet while feeding the belt on. Two person job to do this. Hope this helps good luck!!!!
Sep 23, 2014 | 2007 Toyota RAV4
I have a Miller Shopmaster power source attached to a Miller model 22A wire welder. The problem is when the heat is set above 150 the wire feed pulsates and will not maintain a constant wire feed. Do you...
Check to make sure wire feed brake is not set too tight and that all cables and gun are clean. Also check wire feed wheels are clean and in good shape
Apr 09, 2011 | Miller Welding Tools
System keeps telling me i have a paper jam
Does the paper exit the paper tray?
If not, the half-moon shaped feed rollers may be slippery. Turn the copier on its back side to see the rollers.
Usually they are facing upwards and the rubber side is unreachable. Turn the copier back to its original position.
1. Press the copy button. When the copier starts feeding paper take the power cord off-QUICKLY. If you are quick enough the rollers remain at down position and you can clean them with some kind of rubber cleaning liquid or solvent. Perhaps alcohol, but it tends to dry out the rubber surface.
Jul 04, 2010 | Xerox WorkCentre 4150 Black and White...
Huskylock - 530 - Serger won't create 'loop'
My stitch is good, upper and lower correct, but it will sew along and skip stitches. What do I need to do?, am good at repairing things on it all these years, I havent used it a lot the last few years, but it has started this skipping problem.
Mar 28, 2009 | Husqvarna Sewing Machines
WHEN PAPER FEEDS THROUGH PRINTER COMES OUT WRINKLED. HL-5250DN BROTHER PRINTER
Try these - is paper dry?
Are you using good quality (80 gsm minimum) paper?
Are the fuser rollers (open back of printer, pull down inner paper guide using projecting lugs) in good shape?
Is there any paper debris in the paper path either before the laser unit or on the final path (look carefully at the little paper separator fingers) that is impeding the paper run at one side?
Does the bypass tray give good or bad results? - if good, look for paper debris in the initial feed path.
Are any flexible plastic guides pulled out of shape to face back up the paper path - often caused by pulling a misfeed out backwards?
I find that paper scraps in the initial feed path can be impossible to see, so I have a piece of laminated paper to push through the feed path. It often finds bits I couldn't see.
Mar 05, 2009 | Brother HL 5250DN Laser Printer
Ratchet support
Like any power tool, air tools are safe to operate when the proper precautions are followed. Always read and follow the manufacturer's recommendations.
Aug 27, 2008 | Astro Pneumatic 3/8" Palm Ratchet Wrench
Air Drill Troubleshooting
Aug 27, 2008 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Campbell Hausfeld 1/2" Ratchet Logo
235 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
