Question about Black & Decker Black Decker Dualtemp Soldering Craft Iron CI500S
Soldering iron problem
Can the soldering iron be poisonous?
    President:
  • 2,712 Answers
Solder contains lead which is a poisonous metal. Wash your hands after woking with it.
Posted on Aug 27, 2008
Where does the gauze go in a soldering iron and whats it for?
If the gauze came as part of a kit with the soldering iron it is de-soldering gauze. You put it on a joint, heat it up with the soldering iron and it soaks up the solder so you can remove the item from the circuit board.
Apr 17, 2016 | Welding Tools
How do i descale a team international steam pro 2600w iron
Buy a bottle of descaler and put it in the tank where you normally put the water. Put iron on hottest steam poison and run steam , topping up as required. Rinse thoroughly when finished and iron has cooled. Use distilled or demineralised water for steaming and the iron shouldn't require cleaning again.
Dec 02, 2014 | Irons
How to make my soldering iron melt solder fast
get a lower melting point solder
get a higher temp tip if so equiped
get a higher wattage iron.
Jul 28, 2014 | Welding Tools
What is the uses of an iron stand ?
Hello, the iron stand is used to keep the soldering iron from tripping over that reason why it so heavy. The coil spring is used to hold the soldering iron and dissipate heat. The with some water will help keep the soldering tip clean. GB...stewbison
Jun 22, 2011 | Trisonic NEW SOLDERING IRON STAND HOLDER +...
Having trouble with solder sticking with metal to metal applications
Soldering is intended for soldering alloys together such as copper, silver, gold....solder does not stick well to steel and aluminum...also, you need to use a flux when soldering...this flux cleans the connections of impurities and allows the solder to stick to the metals to be joined...Judging by the iron that you have...it looks like it is mainly used for very small soldering applications where not too much heat is required...If you want to solder larger items(such as soldering to a metal chassis) then I would recommend using a soldering iron or soldering gun with more wattage
Jan 16, 2011 | Weller Bp860mp Battery Powered Soldering...
Iron is not heating up hot enough stained glass soldering iron:
hi friend,
check this out
Consider the wattage of the soldering iron. A good soldering iron will have wattage of 80 to 150. A wattage of lower than 80 is not ideal for stained glass. You need a soldering iron that will melt the solder fast enough for your project. Consider the type of temperature control you want. Some irons will have a temperature control built in the tip. When the temperature drops, it will turn on and when the temperature is reached, it will turn off. Other soldering irons have a built-in rheostat. You control the temperature by turning the dial up or down. A separate rheostat can be purchased to plug your soldiering iron into. Rheostats are highly recommended. This lets you match your temperature to your soldering style and allow you to do decorative effects.
  • Step 2 Consider the heating element. There are two types of elements, ceramic or wire-wrapped. Ceramic core irons maintain heat more efficiently than wound wire heaters. In a ceramic core, the heater core extends into the tip for faster heat transfer. This will keep the tip hot for a longer period so you can work quickly and faster. Ceramic irons maintain their temperature longer and heat up within 30 to 60 seconds.
  • Step 3 Consider the weight of the soldering iron. You want a soldering iron that is lightweight and balanced. You will have less fatigue when using a lightweight soldering iron at long stretches of time. Check to see if it fits your hand comfortably. Check to see if it has a good rubber cushion for your hand.
  • Step 4 Check for the ease of changing tips on your soldering iron. When soldering stained glass, you want to match your tip to the technique you want to use. There are a variety of tips on the market for soldering irons, and you want to be able to change them easily.
  • Step 5 Check the soldering iron to see if it has a heavy-duty cord and a three-prong plug. You want a grounded three-prong plug to prevent the possibility of shock.
  • hope this helps u
    please rate me......................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Weller Welding Tools
    No longer melts solder with tip....
    You have burned out residue on the tip. Clead it off with a damp cloth when the iron is hot. If this doesn't get it all, use steel wool. Immediately afterwards, get flux & solder onto the tip or it will get coated again.
    Jan 24, 2009 | Weller BP860MP Dual Heat Battery Powered...
    What kind of soldering iron??
    For general soldering of wire and electronic components I use a 60 watt Weller iron.
    What you should use depends very much on what you want to solder.
    Dec 09, 2008 | Welding Tools
    Soldering Question
    # Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will give you a nasty burn. # Take great care to avoid touching the mains flex with the tip of the iron. The iron should have a heatproof flex for extra protection. An ordinary plastic flex will melt immediately if touched by a hot iron and there is a serious risk of burns and electric shock. # Always return the soldering iron to its stand when not in use. Never put it down on your workbench, even for a moment! # Work in a well-ventilated area. The smoke formed as you melt solder is mostly from the flux and quite irritating. Avoid breathing it by keeping you head to the side of, not above, your work.
    Aug 27, 2008 | CRL Soldering Iron Temperature Control
    Black & Decker Black Decker Dualtemp Soldering Craft Iron CI500S Logo
    141 people viewed this question
    Top Black & Decker Welding Tools Experts
    Bill Boyd
    Are you a Black & Decker Welding Tool Expert? Answer questions, earn points and help others
