Question about Northern Industrial Tools Air Hammer 2 5/8" Stroke, 3000 BPM, 5.5 CFM, 90 PSI
Hammer problem what is the difference between electirc and air powerd tool?
    President:
  • 2,712 Answers
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools
Posted on Aug 27, 2008
I bought a new jack hammer. After using it for a few hours grease started to come out where the bit is. Is this normal
No thats not normal real JACK HAMMERS on AIR ??? but its not Milwaukee not Bosch not Dewalt but a China brand? if you are have a real jack hammer then its not the right collum because its placed under Hammer drills? and you have also not possible speaking about maybe a little weight rotary hammer ? because ONLY real demolition and jackhammers are very specially made for the long lasting jobs !!! but the weight and power is very important by use the right tool for the right job the most rotary hammers ( exept brands like Hilti and Duss) are not made for long lasting jobs and are made for only working for a short time. its also makes the great price difference between a hammerdrill a rotary hammer a real demolition or a real jackhammer is much higher price. The tools on air Atlas Copco or Ingersoll for the hard and heavy jobs
If you have bought your tool by a hardware store and it is a real jack hammer go immediately back its possible that you are wrong informed by the seller or the budget was the fact. about the price for the tool maybe you have a real jackhammer but have choose a to little model size machine to do the job or its a budget brand online bought China machine. Its a simple question but a hard answer, difficult questions do not exist but difficult answers sometimes.
Regard and luck by warranty and a very small change maybe it is just only a factory flaw.
Apr 09, 2016 | Drills
Looking for some spare parts for this hammer drill...Is there any kind of web store or whatever that can ship worldwide spare parts for this machine?
It is very hard to find parts for tools made in China. There are many look-alikes all with different names. They could, however share parts. If you look on ebay searching "sds roto hammer" you will see many hammers that look similar, different colors. Take a look at the hammer listed below. It is a harbor freight tool. The parts may work. If you have harbor freight in your city, take a look (or on ebay). To order parts for harbor freight tools, look at manual for tool selected, there will be an 800 number to call.
http://manuals.harborfreight.com/manuals/97000-97999/97743.pdf
Sep 07, 2011 | Rotary 1" Sds Roto Hammer Concrete...
Runs but when you try running on a nut it just blows air. should the plates and drum be greased when rebuilt?
The air motor on the 285B needs to be oiled, the hammer section needs to be greased. The symptom described could be in the hammer mechanism, 285B's have 2 different side plates (item# 41) that sit atop the hammer mechanism, tools made from 2005 to 2007 use the old style side plate (item# 41) that has a small lip that need to sit looking toward the hammer case bushing (item# 44) when installed with the small lip facing in to the hammer will cause it to lock, tools made from 2008 to the present have a side plate that is flat on both sides and can be installed in either position. also check the hammer and anvil for cracks and pitting.
Follow this link to view the parts list.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80162944.pdf
Jun 01, 2011 | Ingersoll Rand Ingersoll - Rand 285B - 6...
Air sander problem
Aug 27, 2008 | Taylor Pneumatic: Straight Line Sanders:...
Drill Question
Aug 27, 2008 | Ingersoll Rand 231C Ks 1/2" Super Duty Air...
Wrench Question
Aug 27, 2008 | Ingersoll Rand 1/2" Dr. Super Duty Impact...
Air hammer problem
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Ingersoll Rand Air Hammer - 2 9/32in....
Ratchet Question
* Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools.
Aug 27, 2008 | Chicago Skates Chicago Pneumatic 7830 3/8"...
Air hammer tips
Always keep in mind that air hammers are extremely powerful tools. Thus, particular safety precautions should be taken when using them. Be certain to wear safety equipment such as safety glasses and earplugs. Also, when changing the air hammer's bits, always be sure to unplug the air hammer first. Finally when using an air hammer, always be aware of the position of the tool and work piece. The tremendous force that the air hammer exerts can cause the tool or work piece to jump powerfully. This movement could easily cause injury to the operator.
Aug 27, 2008 | Ingersoll Rand Air Hammer 2 9/32" Stroke,...
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Northern Industrial Tools Air Hammer 2 5/8" Stroke, 3000 BPM, 5.5 CFM, 90 PSI Logo
161 people viewed this question
Top Northern Industrial Tools Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Industrial Tools Air Tool and Compressor Expert? Answer questions, earn points and help others
