Question about Jenny Products Inc AM780-HC4H 4 Gallon Tank 2 HP Horizontal Electric Hand Carry Portable Air Compressor
Compressor Support what are the uses and how for a compressor?
    President:
  • 2,712 Answers
Home Use: Compressed-air power tools can dramatically decrease the amount of time spent on a project. Many homeowners will use smaller, portable units (either hand-carried or wheeled) that move easily from the garage to the house, yard or roof. Common air toolsAir Tools such as brad nailersAir Nailers, reversible drillsAir Drills, and impact wrenchesAir Impact Wrenches require about 0–5 CFM (Cubic feet per minute — units in which air flow is measured). It's important to know if the compressor you purchase will drive the air tool you'll need for your project. For example, smaller air nailersAir Nailers run on 2 to 5 CFM at 70 to 90 PSI, while larger shearsShears, sandersSanders and polishersPolishers require up to 10 or more CFM and 100 to 120 PSI. Business Use: Air compressors used for business/professional applications are often classified “industrial grade.” They're packed with features that let you take on more demanding jobs with more horsepower, more CFM, more PSI and more (longer) run times. Though some industrial-grade compressors are portable, many are stationary units with large-capacity, ASME certified air tanks (up to 120 gallons), greater HP, more CFM air volume and faster recovery time to run a wide variety of air tools for as long as you need them to do the job.
Posted on Aug 27, 2008
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    3.9 V6. How can I remove the A/C clutch?
    You need special tool
    Tools Required ?€¢
    J 37872 Compressor Clutch Holding Tool
    J 6083 Snap Ring Pliers
    Important: Remove the three adjustable dowels from the J37872 Compressor Clutch Holding Tool.
    Install three 5/16 x 1 inch bolts in place of the dowels.
    Remove and discard the compressor clutch plate bolt.
    Use the J 37872 to hold the compressor clutch plate from turning.
    Remove the compressor clutch plate from the compressor.
    Remove the compressor pulley snap ring using the J 6083
    Remove the compressor pulley from the compressor.
    Remove the compressor clutch coil snap ring using the J 6083 .
    Remove the compressor clutch coil from the compressor.
    google J 37872 - to see tool !
    Jan 31, 2016 | 2006 Chevrolet Chevrolet Impala LT
    The ac compressor is seized .I need to replace belt but I need to bypass the ac pulley.Do i need to buy a bypass pulley?
    If the pulley on the compressor will not turn freely, then yes if a bypass pulley exists you would need to use it in place of the compressor.
    If the compressor pulley turns but the compressor is locked up, just unplug the compressor clutch.
    Feb 24, 2013 | 1994 Chevrolet G20
    1999 Pontiac Bonneville SE 3.8L VIN-K I was told a couple of days ago that my A/C Compressor was bad, If i unplug the Compressor from the System will this work so i can still use the pulley 4 the Serp
    If the hub bearing is noisy it will still make noise with the compressor off. That CAN mess up your belt. If it is quiet with the compressor off then you probably have internal compressor damage. Leaving it off WILL NOT mess anything else up on the belt system. If when you do use the compressor and it locks up you WILL lose your serpentine belt. One last thing. If your short on money you can measure the belt system less the compressor and pick up a shorter belt and bypass the compressor. Good luck.
    Jul 21, 2012 | Cars & Trucks
    Air compressor wont start
    For air compressor not working,click the link below :---http://repairhelpcenter.blogspot.com/2012/01/air-compressor-wont-start.html
    -----------Thanks.
    Jan 20, 2012 | Air Tools & Compressors
    What type of oil does this unit take?
    Air compressor oil. I prefer synthetic, but you can use regular compressor oil also.
    Jun 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Refrigerator still makes clicking sound and does not cool after bad start relay was replaced
    Couple Video How To Replace Compressors. I Think Its Not DIY.
    Hope Thats Helps.
    Aug 12, 2009 | Refrigerators
    Compressor
    Unfortunately, the cost to replace just the compressor unit is not much different than replaceing the entire unit.
    May 29, 2009 | Alton Alton 3 HP Air Compressor
    Air Compressor
    Dewalt recommends synthetic oil in their compressors. The dewlat part # 5130427-00 quart, and 5130702-00 for a 4oz size. Available at www.dewalt.com or their service center. I have been using the Lowes brand of synthetic compressor oil. Kobalt oil sells for about $7 and works great. If you do not use your compressor all day like I do, you can use the standard grade of Kobalt compressor oil that sells for around $3. Synthetic oil is for extreme conditions. Good Luck!
    Apr 01, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
    10 year old air compressor cuts off at 10psi
    hello, if you plug the compressor into a none gfi outlet does the compressor still cut off ? it could be one a short in your compressor causing the gfi to trip our your gfi has a ground try the compressor in a diffrent outlet, when you use any other electronic equipment on the gfi does it still trip ? if you use the compressor in a diffrent outlet that's none gfi this should sholve your problem most likely a bad gfi outlet or the compressor is drawing to much amp's.
    Mar 28, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
    Jenny Products Inc AM780-HC4H 4 Gallon Tank 2 HP Horizontal Electric Hand Carry Portable Air Compressor Logo
    276 people viewed this question
    Top Jenny Products Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you a Jenny Products Air Tool and Compressor Expert? Answer questions, earn points and help others
