Question about Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
Oil problem what are the differences between "oli less" and "oil" running?
    President:
  • 2,712 Answers
All reciprocating compressors have a series of pistons that pump up and down inside their individual cylinders to compress the air to a higher pressure. This rubbing creates friction, which creates heat. In order to conserve the life of the pump, you need some type of protection. Some pumps are “splash” lubricated with oil and some have a teflon-type lining in the cylinder. Oil-less compressors are adequate for lighter use applications and have the advantage of being able to run off-level without worry, however even though they are considered low-maintenance, they tend to wear much quicker due to more heat build-up and repair costs could be extensive. Oil-lubricated compressors have the advantage of keeping the pump running cooler and lasting much longer and are built for the professional who takes pride in ownership and will maintain his equipment. However the key is to make sure the compressor sits level so the “splash”-lubrication is effective and reaches all cylinders. If run off-level, it can score the cylinder and do heavy damage over a short period of time. It is very difficult to claim warranty for the owner in this case.
Posted on Aug 27, 2008
What is a good motor oil to run in a 68 chevelle 396 engine
No it is not bad -just more expensive for no real saving. The engine oil should be changed every 5.000 miles as the purpose of the oil is to provide lubrication, hold impurities in suspension, neutralise the acids formed during combustion and give the oil a tension ability ( won't squeeze out from under the bearings under load ). I get all these things plus a heavy detergent action in the oil when I use 30w50 diesel oil plus I get longer engine life. Cheaper than synthetic oils too.
Aug 20, 2014 | Cars & Trucks
My nissan hardbody 3l diesel is using oil there are no visible oil leaks what could be the reason?3l diesel is using oil an there are no visi
potentially you are using to fine a grade oil and the oil is seeping past rings and burning off on startup
Apr 10, 2013 | 2007 Nissan Hardbody 3000TD
When i go to check my oil i find antifreeze in my oli. then when i changed my oli again antifreeze was coming out of the oil pan at the bottom of the motor.
Ok, You are going to have to rebuild the motor that is a given. There are several possible problems that could cause this. Blown head gasket, Cracked Head, Cracked Block, a hole rubbed in the timing chain cover if a timing chain guide came free. I had a Nissan do this. A couple of the holes that the retaining bolts go in for the timing chain guide open directly into a water channel and were letting Anti Freeze run free as well as a hole being ground into the aluminum cover over the timing chain by the chain flopping around. You won't know until you open it up and inspect everything.
Feb 28, 2011 | Jeep Cherokee Cars & Trucks
My grand am gt 2003 has the "oli pressure light", light on. what should i do. what part do i need? i do not want to blow my engine up
OK, first I would check the level. Then, I might check the pressure at the oil switch using a gauge. If it has pressure there, the oil sending switch may be bad.
Or, the viscosity of the oil may be too thin, or the oil filter may be clogged which would mean that changing the oil and filter may solve the problem.
How does the engine run? If it runs without making any knocking or abnormal sounds, then it may be a false low oil pressure reading.
I would try to get this issue fixed as soon as possible, though, as these things won't get better by themselves.
Oct 08, 2010 | 2003 Pontiac Grand Am
There is an Oil pressure sending unit on the left front side of the engine. This is connected to a special fitting that has the tubing that goes to the oil cooler. This is leaking. Where can I get one of...
I usually go to the airport where there is always a company that makes hydraulic lines cheaply. Cost less than trying to order the new part, because they reuse the old end fitting. They just replace the rubber part and the crimped parts.
Sep 07, 2010 | 1999 Chrysler 300M
I got an oli change the other day and the look
The oil is white because water from the cooling is mixed with it. Stop using the car immediately and fix it (most likely a blown head gasket) or you will destroy your engine in a hurry.
Jun 03, 2010 | 2002 Cadillac Deville
No power to fuel pump
if fuses are all good check oli sending unit it has a cut off built in in case oil presure drops so it can be the problem,,, oli sending unit may be leaking or not if it is bad
Jun 30, 2009 | 1999 GMC Savana
How many quarts of oil does my 2001 VZ800 Suzuki Marauder require
the bike should be straight up and down and the oli level should be in the middle of the glass you bike should take around 4 qts
May 15, 2009 | 2001 Suzuki VZ 800 Marauder
Procedure for changing the front and rear axel oil
this is rather simple pull the drain plugs and refill till it starts to run out of top plug besure to use proper gear oli for your vehicel
Dec 07, 2008 | 2007 Dodge Ram 1500 Quad Cab Sport
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
241 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
