Question about Astro Pneumatic 3/8" Palm Ratchet Wrench
Ratchet support are there any safety measures I should be aware of while using an air ratchet?
Lets picture a helicopter. the rotors on top spin. Why doesnt the bottom part spin? it is controlled by a back rotor to keep from spinning. Same concept with the air ratchet. you have a loose bolt that you are putting back together. right now that bolt is loose. Once it tightens and stops, guess what is stopping that ratchet from turning? Your hand... good guess!! now lets say you have a Snap-On FAR 7200 air ratchet rated at SEVENTY foot-lbs... When that bolt tightens and stops turning, your HAND had BEST be prepared to take on that FULL SEVENTY pounds of torque! just a fair warning! I LOVE my air ratchet!!!
Posted on Mar 02, 2010
  • 2,418 Answers
Air ratchets can hurt you. Please be careful if you are new to working with this type of tool. You can get your fingers caught between the ratchet and things you are working on, and due to the fact your hand is caught, your fingers are still pressing on the trigger you can't get loose. Watch for this and learn how to feather the trigger only going full throttle when you have room and a good hold on the ratchet.
Posted on Jul 01, 2009
    President:
  • 2,712 Answers
Like any power tool, air tools are safe to operate when the proper precautions are followed. Always read and follow the manufacturer's recommendations.
Posted on Aug 27, 2008
Where do you oil the air ratchet
Put a few drops in the end where the air hose connects every time you use it. Put oil in the air inlet end and squeeze the trigger to force the oil through to lubricate the rotor vanes and bearings. Also do this before you store the ratchet in the drawer so that oil sits in the ratchet protecting the internals when not in use keeping the rust away.
Jan 20, 2013 | Campbell Hausfeld 3/8" Ratchet
Air ratchet repair kit blue point
See your Snap-on sales rep. or get it repaired at your local air tool repair centre. It is basically a Chicago Pneumatic ratchet.
Aug 28, 2012 | Chicago Pneumatic 1/4" Air Ratchet
Van is overheating
most likley you need to replace the thermostat. but check to make sure your fan is comming on to cool the motor down first check all fuses. under dash and under the hood.
  • 1
    Place a catch pan under the drain valve of your Venture radiator.
  • 2
    Open the radiator valve and drain at least 2 quarts of coolant. Then close the drain valve.
  • 3
    Remove the air cleaner and duct assembly from the top of the engine to gain access to thev thermostat housing. Use a screwdriver and a ratchet and socket if necessary.
  • 4
    Disconnect the crossover exhaust pipe using a ratchet, ratchet extension and socket.
  • 5
    Follow the upper radiator hose towards the engine to locate the thermostat housing.
  • 6
    Disconnect the upper radiator hose from the thermostat housing. Use a pair of rib joint pliers to loosen the clamp, and then slip it off the thermostat housing towards the radiator. Other Venture models may use a worm clamp type, which you can remove using a standard screwdriver or ratchet and socket.
  • 7
    Remove the upper radiator hose from the thermostat housing by carefully twisting and pulling the hose off the fitting.
  • 8
    Unscrew the two mounting bolts from the thermostat housing using a ratchet, ratchet extension and socket. Detach the thermostat housing from the engine.
  • 9
    Note the exact position of the thermostat so that you install the new one the same way. Then remove the thermostat and gasket.
  • Install the New Thermostat
  • 1
    Apply a light coat of room temperature vulcanizing (RTV) sealer to the threads of the thermostat housing bolts.
  • 2
    Set the new thermostat and new gasket in place.
  • 3
    Set the thermostat housing in place and start the two mounting bolts by hand. Then tighten the bolts using the ratchet, ratchet extension and socket.
  • 4
    Connect the upper radiator hose to the thermostat housing.
  • 5
    Tighten the upper radiator clamp over the thermostat housing using the rib joint pliers, standard screwdriver or ratchet and socket.
  • 6
    Connect the crossover exhaust pipe using the ratchet, ratchet extension and socket.
  • 7
    Install the air cleaner and duct assembly using the screwdriver or ratchet and socket.
  • 8
    Add coolant to the radiator using a 50/50 mixture of distilled water and anti-freeze.
  • 9
    Start the engine and check the upper radiator hose and thermostat housing for leaks
  • Dec 08, 2010 | 2000 Chevrolet Venture
    Very little power to craftsman 3/8 ratchet. air pressure set at 80pi.
    add a few drops of marvel mystrey oil to the ail line opening to clean it out and try it again
    Feb 24, 2010 | Craftsman 3/8" Pro Air Ratchet Rapid...
    When you put a socket on my 3/8 air ratchet you can hold it and it doesnt turn the socket
    Make sure your tank is pressurized before using, Also, ratchets have an air adjustment knob that you can adjust how much pressure and power the ratchet puts out. Make sure you oil ratchet before each use with air tool oil
    Aug 24, 2009 | Air Tools & Compressors
    Chicago Pnuematic air ratchet runs continuously
    under the lever you push to make it operate you will se a pin .if this pin is stuck down the ratchet will run all the time.also this could be a bad O ring on this same part,
    May 16, 2009 | Chicago Pneumatic 1/2" Heavy Duty Air...
    Ratchet Question
    * Are easy and economical to use. * Have fewer moving parts for longer wear. * Provide more power and torque than many electric-powered tools.
    Aug 27, 2008 | Chicago Skates Chicago Pneumatic 7830 3/8"...
    How to use a Ratchet
    * Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
    Aug 27, 2008 | Campbell Hausfeld Professional 1/4"...
    Astro Pneumatic 3/8" Palm Ratchet Wrench Logo
    325 people viewed this question
    Top Astro Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Astro Air Tool and Compressor Expert? Answer questions, earn points and help others
