Question about Viking Spray Gun: Hvlp Siphon Feed Spray Gun 13. 9CFM, Fluid Tip Size: 1. 7mm. Air Inlet:1/4",43PSI
Thiner how to
How to add thinner to the paint?
  • 2,712 Answers
Paint to thinner ratio is 60:40, that is 60% paint and 40% thinner. Sometimes it can be 50:50 depending on different occasion. Remember to MIX IT WELL.
Posted on Aug 27, 2008
Do need to thin testors gloss acrylic paint
No- It's best to use testors thinner they sell for there acrylic paint
as a rule of thumb use the the same brand thinners and reducers as the paint your spraying, in this case testors.
Sep 18, 2014 | Tools & Hardware - Others
Pump will not prime after cleaning with paint thiner
Could be that your were using water based paint, so if there was any in the sprayer when you cleaned it out with thinner, this could cause the latex to become a rubbery mass that then blocks up the passage ways. If so you'll need to strip the pump and clean it out.
Oct 04, 2013 | GRACO INC TrueCoat Plus II 16N659
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
The flat screen tv was sprayed with paint right across the screen we need to know if there a way to get it email address is
buy a solvent called paint thinner from paint selling shops .............. using this paint thinner easily paint on your tv screen can be removed without any damage to screen .......remove tv powercord from power socket ......take thinner in small cup ...... take a small piece of soft clothe ..... dip in that cup such that soft clothe becomes just wet ....then slowly clean that particular place where paint is there .....same time keep another soft dry clothe in your other hand ......while cleaning with thinner paint on screen becomes thin then immediately clean it with other clothe..........remember while cleaning thinner's drops should not fall down & go inside tv through edges of screen ....... since this thinner smells like a paint after cleaning tv screen will have paint like smell again you have to repeat above steps but this time you have use soap water or any ordinary cleaning solution ....................................... click below shown link for images of thinner.....,or.r_gc.r_pw.&biw=1024&bih=418&wrapid=tlif131594078475010&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi
Sep 13, 2011 | Samsung Televison & Video
Not sure how much paint thinner needs to be added to paint with a spray gun
That depends on what type of paint you are using, surface to be painted, and air pressure for the gun.
Some type of paint needs different air pressure.
This is something you will learn by practicing. Try mixing a little of paint with some thinner
and spray using different distances from the surface to be painted.
If paint is not getting well distributed on the surface then try adding some more thinner.
Aug 05, 2011 | Air Tools & Compressors
How can i get paint off the outer bag i have the g4 its also on the wire thanks
Best way is to use paint thinner. Where some gloves to protect your hands, then put a little paint thinner ( can get at any paint or hardware store) on a semi damp terry cloth towel/rag. And apply it the area where paint is and slowly work it in and, it will de-solve it, and repeat process until paint is gone. Be careful not to have my any open flames and do not smoke around it. Paint thinner is very flammable. Thanks Mike
Jul 18, 2011 | Kirby G4 Bagged Upright Vacuum
How to get spray paint off of sidewalk
Most spray paints can be removed with paint thinner (mineral spirits). Recommend softening the paint with thinner and scrubbing with a wire bristle brush. This is not an easy operation - it may take some time and lots of effort.
Jun 08, 2011 | Electrical Supplies
2006 sonata has small chip in paint. just noticed some rust starting. what do i do to fix this?
sand it down with some fin grit sand paper, apply a slight coat of rustolium, masking off the area with masking tape, so you dont create a larger area. Then ge touch up paint from your local dealer, some thinner and a refilable pray can, thin the touch up paint with the thinner in a 2 part paint to one part thinner ratio and spay a few coats on, should work.
Sep 30, 2009 | 2006 Hyundai Sonata
Thiner Question
Thinner must be used to thin paint so that it will flow smoothly when used with airbrush.
Aug 27, 2008 | Northern Industrial Tools Northern...
Viking Spray Gun: Hvlp Siphon Feed Spray Gun 13. 9CFM, Fluid Tip Size: 1. 7mm. Air Inlet:1/4",43PSI Logo
447 people viewed this question
Top Viking Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Viking Air Tool and Compressor Expert? Answer questions, earn points and help others
