Question about Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551
Air Compressor question
Does Horsepower rating really matter?
    President:
  • 2,712 Answers
No, When an air compressor is built, it requires a motor or engine to power the process of producing air. The horsepower is not the only component of the equation. It has to be combined with the compressor pump that it runs to produce the air needed. The bigger the horsepower does not necessarily mean more air. Remember to keep your required cfm in mind. Horsepower does not make you work more efficiently, but horsepower working in unison with a quality pump that produces enough cfm for your needs. Make sure when shopping that you look for the running horsepower and not the peak horsepower you get at startup. Some manufacturers have falsely advertised or implied the peak horsepower to be the normal run horsepower. At start-up, there is a surge of power needed to start the motor and can be 1.5-3 times the amount of running power needed. This means the horsepower need for the motor peaks as well, but then drops back down to normal. Many of these manufacturers are involved in a class-action lawsuit for misrepresentation. They have used man’s machismo of “the more horsepower, the better” to their advantage to make sales. These aren’t cars we’re talking about!
Posted on Aug 27, 2008
I have a Honda eu2000i generator to run a Husky TAW-1524p air compressor. Initial start/run is fine but subsequent compressor restarts as demand for air is required, put the generator into overload....
If your mechanical enough to figure out how to lower the air pressure switch on the compressor it would help with start up loads. For instances if your pressure switch is set for 75 psi. Lower this to 60 psi. or as low as you can and still operate equipment. Otherwise depending what horsepower and voltage {guessing 110 vac) the motor is, I would try an Hard start capacitor for refrigerators or air conditioners. They are rated by horsepower and have a built in relay that kicks it off automatically after starting . You can find these at any appliance or a/c & heating supply house.
May 11, 2014 | Heating & Cooling
How much micro frard will i use for air compressor 0.5 hp
I don't believe there is a standard value for a specific horsepower rating. I have serviced and replaced plenty of these capacitors and the manufacturers say it is important to use only the value that the motor is originally supplied with. I have not seen it correspond to horsepower directly. Some motors use both a start and a run capacitor and I've never seen them identical. Horsepower listed ratings can vary wildly if it is not directly listed on the motor spec label. I believe .5hp corresponds to about 6 to 8 amps at 120 volts.
Oct 16, 2012 | Air Tools & Compressors
Hi.. heatman101, I need a replacement for a dual capacitor, its made by aerovox, it is round & looks like its made of gray pvc plastic. im not sure if this is the part # printed on it (SH 1238). it...
If you have the # off the compressor, you can contact the manufacturer,(Bristol, copeland , etc)
they can tell you by figureing out the horsepower.or your local supply house can do it for you.
Jul 27, 2011 | Heating & Cooling
What is the HP and BTU rating of the SK1A1C-L2W COMPRESSOR
This unit uses a 1/2HP compressor. 12,000 BTU's to a horsepower, therefore it has 6,00 BTU's
Nov 13, 2010 | Turbo Air MSR-49NM Refrigerator Commercial
Sorry bought magnum compressor 3phase but also runs 240v cannot get it to run on 240v any info would be realy helpfull ta Peter
if you have a 3phase motor it will only run using 3 phase power no matter what voltage or you can get a phase converter but they are pricey and varies with what horsepower your motor is
Oct 19, 2010 | Magnum Air Tools & Compressors
I have an ssr-epe250 and need to change the pressure setting from online @93 & offline @ 103 psi. i need 125 psi. i just changed the controller and cannot get back to operating specs i need.
controllers do not come setup for a specific compressor. you need to be able to get into the factory setup.you will then be able to change rated pressure, horsepower etc. look at the name plate to get rated pressure. once the rated pressure has been changed you will be able to set your operating pressure to 125 online and 115 or less offline
Aug 10, 2010 | Ingersoll Rand Stationary Air Cooled...
I would like to connect a pressure switch to the motor starter
hi! there, single phase compressor motor need a starting capacitor base on the rated capacity in horse power,you can check this on the tag of the compressor motor how many horsepower was indicated,it should be for single phase motor starting capacitor has a capacity of micro farads.for a 1 horsepower = 15 to 18 micro farads stating capacitor if you have more than 1 horsepower you can basically proportion the value of capacitor you need or ask the dealer how much capacitor you need on your motor the connection of pressure switch with a four terminal should be connected both on common line L1 and running capacitor line L2 .if you open the cover of pressure switch there are 4 terminals,2 terminals are connected when normally close or no pressure they connected on series connection on the common line one terminal connected to common line of the compressor and the other terminal on L1 to the pushbutton switch to L1 supply line.the 2 other terminals also connected in series withe line capacitors L2 to yhr power supply line.hope this will help you a lot.just rate my fix thanks a lot.
Apr 20, 2010 | Air Tools & Compressors
HP OF R134-ADMIRAL REF
it will be located on the compressor plate of the rateing of hourse power and amperage with the amount of freon needed to fill it.
Jun 25, 2009 | Matsushita DD73C14GAU6 1/4 HP R134...
Nail Gun how to
One of the factors used to designate compressor power is motor horsepower. However, this isn't the best indicator. You really need to know the amount of air the compressor can deliver at a specific pressure. The rate at which a compressor can deliver a volume of air is noted in cubic feet per minute (cfm). Because atmospheric pressure plays a role in how fast air moves into the cylinder, cfm will vary with atmospheric pressure. It also varies with the temperature and humidity of the air. To set an even playing field, makers calculate standard cubic feet per minute (scfm) as cfm at sea level with 68 degrees F air at 36% relative humidity. Scfm ratings are given at a specific pressure–3.0 scfm at 90 psi, for example. If you reduce pressure, scfm goes up, and vice versa. You also may run across a rating called displacement cfm. This figure is the product of cylinder displacement and motor rpm. In comparison with scfm, it provides an index of compressor pump efficiency. The cfm and psi ratings are important because they indicate the tools that a particular compressor can drive. When choosing a compressor, make sure it can supply the amount of air and the pressure that your tools need.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Gun how to
Aug 27, 2008 | Irwin 24" Bar Clamp Multi Position Jaw
Porter Cable 4 5 Gallons 150PSI Job Boss Oil Lube Mobile Air Compressor ? C3551 Logo
284 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
